Mon Dec 15, 2014 | Total posts : 2 |
| Topic: What should be the direction of the basement ramp for a east facing with 45*tilt
What should be the direction of the basement ramp for a east facing with 45*tilt. Should the ramp start from East of North East corner or East of South East Corner? |
Articles that might interest you! | | EAST FACING PLOT A north-east facing plot is best for all type of constructions, whether a house or a business establishment. However, .. | | Basement Design Ideas Do you want to make your home a multi-purpose location? Design a basement to serve various purposes like gym, home off.. | | Vastu Guidelines for Basement Vastu says to build basement in northern and eastern portion of the house. Basement can be used as store room and offi.. | | The 4 Cardinal Directions The directions are one of the most important factors in both Feng shui and Vaastu. The positioning of main entry door, v | | Basement Ceiling Finish your Basement Ceiling with great ideas from GharExpert ceiling design gallery. Make your basement more inviting.. | | Basement Flooring Basement Flooring need extra care because of moist and dampness conditions. Read details about basement flooring optio.. | | Basement Interior Design Basement interior design can fulfill your dreams of enjoying more space. You can highlight dark space of basement in e.. | | Basement Walls Basement walls always needs special care because of outside pressure of soil. Read about What care should be taken for.. | | Water Proofing Treatment for Basement A dry basement is a fun place to have. Usually home owners do not care for proper design of the basement at the time o.. | | Why should cement pointing be done on walls? According to the drawing , in elevation the outer face shown with out plaster & brick face finishing is required by th.. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
