How should the drainage water flow .. In which direction the water should flow o
Fri Jan 22, 2010Total posts : 1
ic011031
ic011031
Topic: How should the drainage water flow .. In which direction the water should flow o
How should the drainage water flow .. In which direction the water should flow out of the house or plot?
Mon Jan 25, 2010Post  #1
Deepti
Deepti
Post subject: Drainage water flow
The drainage pipelines of the bathroom and the kitchen should flow in the east or the north directions. The pipes of the toilets and bathrooms should be diverted to the west or the north-west and then the water flow should be built accordingly.
roofing on open terrace
2790
2187
pile work
3132
2801
Last answer on 7/3/2020 11:53:31 PM. Forum started by mamta
2154
Need your guidance
Last answer on 8/20/2012 12:27:18 PM. by S L Gupta (Civil Engg). Forum started by sam_m400
1823
how to start a commercial interior project steps and precautions to flow...
Last answer on 6/21/2021 4:15:41 AM. by sandeep yadav. Forum started by sandeep yadav
2572
3378
2968
Last answer on 9/1/2015 2:51:50 AM. by JAI PRAKASH. Forum started by sher singh daulta
2100
My House is north facing please tell which is best direction for installing wate
Last answer on 11/19/2012 11:30:26 AM. by Amit Hasija. Forum started by Anuj Anand
2440
2126
1786
which direction i keep small water fall at balcony.
Last answer on 2/6/2010 12:24:42 PM. by sabina vanjani. Forum started by vipin deshpande
2245
2108
How to use Feng Shui to attract wealth?
Last answer on 12/27/2013 5:13:21 PM. Forum started by soni gupta
5070
6422
2867
Need help regarding boundary wall construction
Last answer on 8/27/2013 11:59:55 AM. by S L Gupta (Civil Engg). Forum started by sonu.211
28
hUsBaNd =//=wIfE[[ 91-8769373431]]=//=Divorced problem solution
Last answer on 1/7/2025 11:20:19 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:20:12 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:56 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:49 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:43 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:37 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:30 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:24 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:16 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:10 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:19:04 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:58 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:51 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:45 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:38 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:32 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:26 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:18 PM. Forum started by rupeshji
Last answer on 1/7/2025 11:18:11 PM. Forum started by rupeshji
Husband Wife 918769373431~LoVe PrObLeM SoLuTiOn
Last answer on 1/7/2025 11:17:54 PM. Forum started by rupeshji
What are various types of valves for water pipe lines?
Valve is suitable means of connections for inserting and controlling the flow of the water.Nominal size of stop valve ..
Which are various brands of pipes for drainage of soil water?
Brands of pipes for drainage of soil water-C.I. Pipes-CIC..........
60
60 Tips to Save Water
Vastu for Water Tank
Water for Construction
Rain
Rain Water Harvesting
Preventive
