should we have bells for the pooja room doors
Tue Feb 02, 2016Total posts : 3
Radhika
Radhika
Topic: should we have bells for the pooja room doors
Tue Feb 02, 2016Post  #1
Puja room: Vastu guidelines
• The puja room is best located at the NE corner of the house in terms of Vastu. A water source such as the well, is also best located at the NE of the house plot.
• Other desired directions for location of the puja room are East or North, but not South.
• If it is a very big plot the puja room can be constructed in the center of the plot or center of the building.
...• Puja room or shrine should not be located in the bedroom.
• Puja room should not be above electrical appliances or gas stoves.
• Puja room wall should not touch or share the same wall as the toilet. Ensure that the toilet is not adjoining the puja room, not opposite, and not even above or below the prayer room.
• Puja room and shrine should be immaculately clean and neat; avoid dirt or clutter and keep it fragrant.
• Puja room should always be on the ground floor and never in the basement.
• The roof of the puja room should be lower in comparison to the other rooms on the same floor. One can use false ceiling for the same, if major renovation not possible. It is beneficial to build a threshold at the entrance of the puja room.
• White or light yellow marble work in the room is auspicious. The color of the walls can be white, light yellow or light blue.
• The doors of the puja room should not close or open automatically. A spring or door-closer should not be fixed on this door.
• The materials required for the Puja or the Puja Samigri should be kept in the South East direction. The puja room should not be used as a store for other materials. Any item, showpiece, images of god etc. removed from puja room for any reason should not be kept elsewhere in the house, and should be properly 'visarjit' (disposed of) in a river.
• If you are forced to have your prayer in the kitchen, have your deity in the North-east of the kitchen, facing west. Never have the prayer area in the bedroom.
Puja room shrine
The puja room shrine is usually a shelf with wooden/concrete or Cuddapah/marble/granite stone partitions with an altar at the bottom of the shelf for doing puja. It is convenient to have the shelf closed with doors which can have decorative perforations to hang little bells that chime as you open or close the doors. The bells can also chimed during a puja, in addition to chiming the bell exclusively used in pujas.
• If a mandir (shrine) is built of wood, steel etc. the top of the shrine should never be pointed/sharp.
• The image or portrait of the Kula Devata (family deity) as well as the IShTa Devata (preferred deity) should have prominent places in the puja room. Since Ganesha is worshipped first in all pujas, it is customary to place his image or portrait too in a prominent position. Portraits of other Gods are placed according to preferences and convenience.
• Since we do puja sitting on the floor of the room, it is convenient to have the images/portraits we do puja to, in the bottom row of the shrine. The image/portrait we do puja to may be taken out and placed on the altar (that usually prutrudes the bottom compartments of the shrine-shelf, decorated and worshipped. Where this is not possible, puja can be done to the portrait in its own area in the shrine, although some pujas might have regulations regarding placement of image/portrait.
• East and the north are the two acceptable orientations for the base of Shiva lingam in any temple as stipulated in Agama Shastra. So the base Shiva lingam is noticed either facing East or North direction in any temple. While the devotee, who is worshipping Shiva Lingam is facing the East the base of Shiva Lingam shall be oriented towards north dirction. When the disciple is facing north while worshipping, the base of Shiva Lingam shall be oriented towards East. Base here shall mean the point from where the Abhishek liquid (Water or Panchamrit) flows out of Shiva Lingam.
• The images/portraits of Gods may face any direction except South. Images should not be kept facing each other. Broken images and torn pictures should not be kept in the puja room. We should not face South as we prostrate to the deities.
• The faces of god should not be covered with anything including garlands and flowers.
• If a lamp is placed in the puja room, it should always be in front of the god.
• No bell should be hung in the puja room.
• Never place any photographs to dead people in the pooja room.
Sun Feb 07, 2016Post  #2
Please check with a Vastu expert.
Fri Sep 07, 2018Post  #3
           Thank you.
6171
i need sliding folding system in wooden door in pooja room
Last answer on 6/6/2012 2:15:06 PM. by Ar. Manoj Ralen. Forum started by ajay mittal
2801
if the pooja room was kept direct from main door
Last answer on 1/23/2013 12:10:53 PM. Forum started by arul prakash
3210
Door direction
Last answer on 7/3/2020 9:10:36 PM. by S L Gupta (Civil Engg). Forum started by Rohit Patel
5883
Last answer on 7/3/2020 11:50:34 PM. by S L Gupta (Civil Engg). Forum started by sathiyamurthy.s
6198
Vastu and Brahmasthan
2071
Pooja Room Door
Last answer on 6/25/2016 11:04:51 AM. by S L Gupta (Civil Engg). Forum started by Meda Kameswara Rao
3163
can i keep pooja room in master bed room
Last answer on 12/31/2020 2:32:00 AM. by Abhishek. Forum started by pallavi sinha
2123
Do pooja room. Beside we construct store room
Last answer on 12/11/2014 6:17:56 PM. by JAI PRAKASH. Forum started by kumar
3741
Pooja Room Vastu
Last answer on 10/3/2015 11:17:32 AM. by S L Gupta (Civil Engg). Forum started by sam
1763
Our house is an appartment having 2 rooms and a kitchen and an attached bathroom
Last answer on 11/1/2015 6:55:44 PM. by JAI PRAKASH. Forum started by Shanthy
1503
Recently I bought this flat shown in attachement with west facing. builder chang
Last answer on 9/9/2016 11:59:33 PM. by bhuvaneshwaran bn. Forum started by Pramod
2586
WE HAVE BOOKED A 3-BHK APPARTMNT HAVING MAIN DOOR FACING NORTH,MASTERBEDROOM ENT
Last answer on 10/2/2009 12:05:38 PM. by Priti Arora. Forum started by loknath
5684
Having a plot of 30'X40' south facing, want to know floor plan up to 700 sq ft w
Last answer on 2/16/2019 2:25:41 AM. by Amit Hasija. Forum started by viairsung
2270
we have 2 kitchens,2 entrance doors facing west since partion having door plz su
Last answer on 9/24/2010 7:41:25 PM. Forum started by pradeep
2690
DOORS
2027
if pooja room to be locate beside kitchen
Last answer on 7/4/2020 3:04:17 AM. by JAI PRAKASH. Forum started by ravi
2222
30*60 plot plan with pooja room
Last answer on 4/5/2017 12:59:26 PM. by S L Gupta (Civil Engg). Forum started by R.K.
1454
Pooja room kid Ethan mein rakhna chaiye
Last answer on 6/5/2017 12:53:10 PM. by S L Gupta (Civil Engg). Forum started by juliesbastin
17
18
Pooja
Pooja room designs in wood
Pooja
Pooja Room Vastu
Decoration
Decoration for Diwali with Diyas, Diwali Lights and much more
How to do decoration for diwali? Know more intant ideas for Diwali decoration. Diwali festival, its significance, diya..
Aluminium
Aluminium doors
Are you looking for a strong door for your home? Aluminum door is right choice for initial security of your room. Thes..
Panel
Panel Doors- Advantages and Disadvantages
Panel doors are quite popular in homes for various reasons. Panel doors are hard or provide more security and privacy ..
Buying
Buying Guide for Garage Door
Garage
Garage door parts
Understanding garage door parts can help you in choosing the style of garage door, maintaining, and increasing the life.
Garage
Garage Door
A Garage door is a door of garage that should be large enough to move vehicle in and out. When choosing a garage door ..
