sir,idecided to construct stilt 2 floors; for which i called for quotations fr
Mon Jul 23, 2012Total posts : 2
d.surendramohan
d.surendramohan
Topic: sir,idecided to construct stilt 2 floors; for which i called for quotations fr
sir,idecided to construct stilt 2 floors; for which i called for quotations from builder,onper sft.basis. the builder charges seperately for stilt floor. is it correct. pl.reply me
Mon Jul 23, 2012Post  #1
Dear Mohan
      The rate persft given in quation or tender is on mutual under standing or for which area you called for rates and what are the rates which are acceptable to you are not.
Secondly  if contractor given rates for
1 stilt floor with foundation
11. First story rate i.e. above stilt
and second story rate. Now it is up to you to see the resonablity of rates and you consider these rates or not
Mon Jul 23, 2012Post  #2
Ar. Manoj Ralen
Ar. Manoj Ralen
Dear Sunder mohan,
It is always better to ask the contractor to detail out the components in his quotation. For example, you can ask him to provide cost of foundation, cost of stilt floor, ground floor and other floors separately. Also, it would be very helpful to define what work would be performed on each floor. Contractors do not follow a standard mechanism so once they list out  the work items then you would understand the breakup better. There is a cost estimator tool that lists some of the work items that should be performed in a single story construction.
Once he gives you a rate list, you can post here all the work that he is offering and some one from the forum group would be able to review whether he has intentionally left out some thing or is double charging some thing or not.
Stilt floor in construction
Last answer on 2/1/2021 11:53:22 PM. by Nikita. Forum started by viren
1940
Quotation from the Builder.
Last answer on 7/17/2013 12:27:25 PM. by S L Gupta (Civil Engg). Forum started by ananth
3244
how many floors can be constructed in a 242 sq yards plot in vikas puri?is stilt
Last answer on 4/1/2021 12:37:58 AM. by seema tyagi. Forum started by DR GOEL
2398
is it advantageous to buy flat with stilt 2 floors or stilt 4 floors
Last answer on 7/29/2014 12:12:50 PM. by S L Gupta (Civil Engg). Forum started by Jacob Alex
1608
Hi, I have a 40x60 plot and planning to construct Stilt 3 floors. I have got a
Last answer on 8/21/2017 12:46:41 AM. by S L Gupta (Civil Engg). Forum started by a_sharath81
3519
Dear Sir/madam, Kindly show me elevation of Bunglow which is Stilt floor Bungl
Last answer on 6/19/2021 6:43:20 AM. by Kiran Ghorpade. Forum started by Shridhar Devsani
1488
I have plot in Coiambatore, I wish to construct a Commercial building Stilt park
Last answer on 5/22/2017 1:38:27 PM. by S L Gupta (Civil Engg). Forum started by R. Ramasubramanian
2340
PAINTING
Last answer on 6/14/2011 1:16:15 PM. by S L Gupta (Civil Engg). Forum started by sabakhan
3642
I want to built a house with stilt,ground floor
Last answer on 8/30/2021 6:11:55 AM. by S L Gupta (Civil Engg). Forum started by venkatesha
Estimate for Stilt + 2 floors residential building
Last answer on 1/18/2013 9:07:56 PM. Forum started by PRAKASH
2030
whats remedy fr wall dampnass
Last answer on 2/25/2022 7:03:51 AM. by helloaarti21. Forum started by rakesh chopra
2304
according to vastu which colour is sutiable fr a couplr room
Last answer on 6/11/2013 12:45:58 PM. by Pavan. Forum started by vani
2573
1141
Please suggest the quotation to be fixed forthe carpentery work for interiors?
Last answer on 7/3/2020 10:57:09 PM. by S L Gupta (Civil Engg). Forum started by zakia sultana
1370
DEAR SIR, REALLY WHICH IS GOOD DESIGN THIA MODEL LET ME KNOW CLEAR MODEL FO
Last answer on 7/19/2016 10:40:20 AM. by S L Gupta (Civil Engg). Forum started by Dr.Vijayakumar gampa
2784
COST OF BUILDING
Last answer on 11/14/2012 12:44:19 PM. by S L Gupta (Civil Engg). Forum started by Altaf
7101
Cost of stilt floor construction
Last answer on 10/1/2009 3:08:55 PM. Forum started by Amar
Help required for construction of basement+ stilt+ 3 floors on 205 sqyd plot in huda gurgaon sector
Last answer on 3/16/2017 10:24:00 PM. Forum started by Mukesh
1832
Last answer on 9/8/2021 6:08:07 AM. by S L Gupta (Civil Engg). Forum started by Gujjalaraja
15
17
Terrazzo
Refinishing Hardwood Floors
Checklists for flooring
Comparison
Linoleum
Linoleum Flooring
Linoleum flooring is a popular choice when you are looking for style and ease at the budget. You can choose any color ..
Choose
Choose Flooring for your Kitchen
Kitchen flooring should be fit into the kitchen design in such a way that will work according to your personal needs a..
