Sun Jan 15, 2017
deepu
Topic: size of pillar, no. of pillar- reg.
I am Deepak, now I like to start a construction of g+2 door. Im asked my builder to use 4 nos of 20mm and 2 nos of 16mm rods in pillar size of 15"*9" pl. Suggest me shall I use this size, and pl suggest me what is the correct size of plinth beam and column size what grade of ms rod to be use.
Pl. Do me the needful sir
With regards
C.Deepak
Mon Jan 16, 2017
Dear Deepak,
The column size seems to be correct and plinth beam should be 9''x6'' with 4 nos MS bars of 12mm dia
65223
Last answer on 7/3/2020 11:37:34 PM. by
syed
Jitendra Sindhi
2409
start construction Steel use
Last answer on 12/24/2012 4:30:19 PM. by
mollybisa
inder
9181
pillar size in distacce
Last answer on 5/8/2017 1:45:45 PM. by
Pandu
jaybiswa
2683
Last answer on 8/16/2016 11:39:31 AM. by
freekundli
MASTHAN
4355
Last answer on 1/7/2017 7:22:09 PM. by
roshan
roshan
Structure strength to build additional floor(G+4)
Last answer on 12/14/2014 10:12:17 PM. Forum started by
saravanan
3595
Last answer on 8/12/2015 11:59:23 PM. by
jahangir
3745
small size plot, pillar location, size and number of required pillars, floor plan
Last answer on 3/20/2014 2:49:26 PM. Forum started by
basbrem
4361
Last answer on 12/17/2020 5:55:40 AM. by
K Srinivasan
2878
Pillar distance and steel rod dia
Last answer on 8/1/2014 7:37:46 PM. Forum started by
SAROJINI
2547
Foundation design
DavidFlores18
nithun
1515
Guide me
Last answer on 3/22/2017 12:35:27 PM. by
Subash
4353
Last answer on 6/4/2021 2:21:04 AM. by
r.n.misra
3224
Last answer on 9/24/2014 11:34:03 AM. by
somasekhar
Last answer on 11/15/2016 1:51:43 AM. Forum started by
K Srinivasan
891
Hi All,I bought a house which is already built G 1.The house consists of 12 pill
Last answer on 8/1/2018 11:51:13 PM. by
vinay
936
Last answer on 8/1/2018 11:52:28 PM. by
vinay
12412
First floor construction
Last answer on 7/4/2020 12:01:33 AM. by
chidambar
6392
How do I decorate a Pillar in my bedroom
Last answer on 7/3/2020 9:58:48 PM. by
cleopatra
2451
Brick Pillar
Right size cupola
What is the recommended size of wooden boards?
Maximum length of the board should be 180 cm.
What is binding wire
