Home -> Forums -> Construction -> Cement Concrete -> sloping roof
sloping roof
Wed Jul 20, 2011Total posts : 3
ekonagu
ekonagu
Topic: sloping roof
helo sir
what to do to avoid leak on slope roof. the workers are using less water on the concrete mix for the sloping roof.what is the best method to avoid leak on concrete on sloping roof .pls advice
Wed Jul 20, 2011Post  #1
Dear Ekonagu
      I think you have laid the slab /roof. The best method is to finish the roof top with cement shullary and water proofing compound at the time of laying the slab.For this situation do bitumen painting on the roof surface, stick polythen sheet on the bitumen when it is hot and press fully.Then lay the layer of brick tiles and sealed the joints with cement mortar and cement pointing on tile surface. For more detail you should visit gharexpert. com website DAMP PROOFING SECTION where lot of articles above damp proofing help you.
Thu Jul 21, 2011Post  #2
ekonagu
ekonagu
hai  we have already laid the roof for some portion.some more protions needs to be done,so to avoid the leaking is it ok to do the same as u mentioned above? or some thing else ?
Thu Jul 21, 2011Post  #3
Dear Ekonagu
If you do the process according to the instruction then the roof will be leak proof.
2992
2377
1764
Sample Plans and Exteriors Design ( not in Sloping Roof)
Last answer on 10/11/2012 3:34:41 PM. by Amit Hasija. Forum started by KAUSHAL KUMAR
4349
rate comparison
2089
Low cost roofing solution over a slanting slab for internal cooling
Last answer on 12/1/2013 8:03:10 PM. by Girish. Forum started by Girish
1364
I have a slope roofed house how can I fix the water tank in south west , can I d
Last answer on 10/25/2013 11:37:04 AM. by S L Gupta (Civil Engg). Forum started by Mrs.sundar
1972
I am constructing the first floor of my existing house. The laterite walls and t
Last answer on 5/30/2011 12:21:49 PM. by S L Gupta (Civil Engg). Forum started by nancy
3404
Columns and beams
Last answer on 12/16/2020 3:02:45 AM. by S L Gupta (Civil Engg). Forum started by Biju
3368
Slope on a RCC flat roof
Last answer on 8/20/2018 12:30:20 AM. by Amit. Forum started by Arvind Bhaskar
3748
How to cast sloped/slanted roof, as our architect described inablity to use vibr
Last answer on 3/5/2013 12:11:16 PM. by S L Gupta (Civil Engg). Forum started by mrityunjay singh
42599
Labour Cost for Roof RCC work
2662
flooring slope in bathroom, shower , kitchen & rooms
Last answer on 1/2/2021 7:08:17 AM. by S L Gupta (Civil Engg). Forum started by archi
3013
1835
8421
Roof Beam crack
1496
I am planning for a two storied 2BHK house in my village. I am thinking of exter
Last answer on 7/3/2020 10:33:53 PM. by S L Gupta (Civil Engg). Forum started by Sumathi Iyengar
1648
2054
4648
3470
Cost of concrete walls
1794
STP
3108
3652
4349
rate comparison
3205
Concrete Mixture
2090
15807
6471
2380
leakage in new slab
1528
Guide me
5123
2536
Civil Eng Stair Design
2536
Related to Sunken Slab
1859
1998
Concrete Hollow Block Masonry
2415
roof concrete
3200
Ready Mix Concrete
Cooper
Aluminum
Aluminum Roof
Asphalt
Asphalt Shingles Roofing
Wood
Wood Roof Shingles
