Sun Oct 12, 2014Total posts : 4
Topic: what is the solution for stopping leakage of terrace without breaking existing c
what is the solution for stopping leakage of terrace without breaking existing coba/ tiles
Mon Oct 13, 2014Post  #1
Unoara Design Hub
Unoara Design Hub
Dear Sanjay,
You need to post some photos and provide more description. Is the leak due to Water Tank or due to rains?
Is it a flat roof or a sloping roof building?
Solutions will differ.
UNOARA DESIGN HUB
Bangalore
Thu Oct 16, 2014Post  #2
There are many solutions available in the market. please consult an experienced civil contractor for more suggestions.
Thu Aug 27, 2015Post  #3
sam
sam
Post subject: Leakage
For leakage in terrace tiles, there are only few products in the market currently, which guarantee permanent solution. You can try a series of products available at Roff Pidilite, according to your problem. I had similar problem of leakage in my terrace tiles and got it fixed with Roff. I feel it is very durable and easy to apply.
Thu Aug 27, 2015Post  #4
Correct but good thing is to remove them and re-install.
1800
2298
9894
2932
2292
2768
roof leakage
2351
2622
roofing on open terrace
1911
There's a basement space in a building and it locates at backyard of lower level
Last answer on 10/24/2013 11:34:35 AM. by S L Gupta (Civil Engg). Forum started by parth
3013
1970
water dampness
Last answer on 11/13/2014 6:26:53 PM. by JAI PRAKASH. Forum started by sunder
2483
Extending the existing cantilever
Last answer on 3/30/2017 12:58:03 PM. by S L Gupta (Civil Engg). Forum started by Abhi
1765
1668
2380
leakage in new slab
3426
I am planning to renovate my floor with vitried tiles. Contractor is suggesting
Last answer on 5/17/2017 3:00:33 PM. by S L Gupta (Civil Engg). Forum started by RKG
2186
I want to cover my terrace because of leakage problem during rains.If i want to
Last answer on 9/12/2014 9:53:08 PM. by JAI PRAKASH. Forum started by Akshata Rao
23
27
Roof Garden
What are various types of valves for water pipe lines?
Valve is suitable means of connections for inserting and controlling the flow of the water.Nominal size of stop valve ..
Electric
Carpet
Carpet Cleaning Tips
Preventive
Storage
Storage Solutions for kids Room
Kids require a lot of storage space to place their toys and playthings. Proper storage ensures safety to the kids as c..
Green
