Sat Jan 17, 2015 | Post #1 | JAI PRAKASH
Join date: May 2014 | 3D theme based floor tiles are available, which were look like mural floors. You have to search for them in different shops. | |
Sun Apr 05, 2015 | Post #2 | John709
Join date: Apr 2015 | Post subject: What are special types of flooring?
Hi! Thanks for article will use it for my | |
Sun Apr 05, 2015 | Post #3 | John709
Hi! Thanks for article will use it | |
Mon Jun 15, 2015 | Post #4 | jamessmith123
Join date: Jun 2015 | Post subject: What are special types of flooring?
Mon Jun 15, 2015 | Post #5 | jamessmith123
At Flooring Village we aim to make buying Laminate flooring, Aqua-Step 100% Waterproof laminate, Engineered wood, Solid wood, Rugs and all flooring accessories as smoothly as possible. - | |
Tue Jun 16, 2015 | Post #6 | steve7876
Join date: Jun 2015 | Extremely very good work and writer
write so well . | |
Wed Jun 17, 2015 | Post #7 | JAI PRAKASH
Wed Jul 08, 2015 | Post #8 | S L Gupta (Civil Engg)
Join date: Mar 2008 | Dear John See more about Vinyl flooring
Vinyl
flooring is generally used to ornament floor in residential and non
residential buildings. Vinyl flooring is laminated, solid resilient,
unbreakable and flexible having non porous surface. This flooring is
resistant to mild or diluted acids, alkalis, soaps, detergents and
petrol. It is high wear resistant and can be cleaned easily with wet
cloth. If it is cleaned immediately, concentrated acids and alkalis have
no effect on the surface of floor. Do not throw burning cigarette butts
or match sticks on floors. To avoid scratches on the surface of floor,
do not drag any heavy object or furniture on floor.
Constituents of Vinyl FlooringVinyl flooring consists
of thermoplastic binder, filler and pigments. The thermoplastic binder
should consist substantially of one or both of
• Vinyl chloride polymer • Vinyl chloride copolymer
Vinyl flooring material should confirm to IS Number (IS: 3462).This
floor material is available in various thicknesses i.e. 1.5 mm, 2 mm,
2.5 mm, 3mm and 4 mm. It is available in shape of tiles or roles having a
length from one meter to ten meters.
Adhesive for Vinyl Flooring
Rubber based adhesives are used to fix PVC flooring over concrete,
wooden and metal sub base flooring. PVA based adhesives should be used
for concrete and wooden sub floors but they are not good for metal base
and on damp floors.
How to prepare sub base for vinyl flooring?
Step 1: Prepare hard, dry and damp proof baseSub
base should be hard, dry and damp proof. If vinyl flooring is laid on
damp base, moisture slowly damages adhesive resulting in separation and
curling of PVC sheet from the base. Vinyl flooring can be laid on any
sub base such as concrete floor, wooden floor.
Step 2: Lay damp proof base concrete in two layersAt
ground floor, the base concrete should be laid in two layers with damp
proof layer including damp proofing on walls at least up to 6 inches
from floor level. In case of new work, it should be left for at least
one month for drying.
How to install vinyl flooring?
Step 1: Clean sub base of all dustSub
base for vinyl flooring should be cleaned of dust. It should be dry.
The surface of sub base should be free from grease and grit.
Step 2: Set the temperature between 20 to 30 degrees centigradeBefore you lay flooring, materials should be stored at room temperature at for 24 hours. During
installation the temperature should neither fall below 20 degree
centigrade nor shall exceed 30 degree centigrade and at least for 48
hours.
Step 3: Use adhesives on sub base for proper fixingVinyl
flooring should be first laid for trial without using adhesive
according to required layout. Then the adhesive should be applied on sub
base and backside of PVC sheet for proper fixing. Usually after half an
hour when adhesive is sticky to touch, the PVC sheet should be pressed
on the sub base. Then the sheet should be pressed using a roller
weighing about 5 kg to develop proper bond with sub floor.
Step 4: Do installation in dry conditionsMake
sure that there is no air between the sheet and back ground surface.
Avoid floor installation under high humidity conditions.
Step 5: Check alignment and clean top surfaceAfter
laying each row the alignment should be checked. Also make sure that
there are minimum joints between two rolls/tiles. After completing the
work, the top surface should be cleaned thoroughly by using wet cloth
and solvent.
Note : After installations, do not use flooring at
least for 24 hours. Metallic edge strips should be used to protect edges
of flooring.
Benefits of blended vinyl flooring
- Versatility
- High durability
- Low maintenance
- Easy to install and clean
- No need to hire a professional for installation
Drawback of blended vinyl flooring
It can be cut, scratched, burnt and bent easily.
Mon Jul 13, 2015 | Post #9 | Sence1953
Join date: Jul 2015 | Post subject: crew locksmith 24 hours services
Before proceeding to explore the sort of training that one needs in
order to become a forensic locksmith, it would be essential for us to
have a brief overview on whom the forensic locksmith is, and what he is
involved in on a day to day basis. This we would be doing out of
appreciation for the fact that many people are unfamiliar with these
professionals, and it wouldn't be altogether far-fetched to speculate
that some of us may be encountering the term 'forensic locksmith' for
the very first time in this discussion.
Mon Jul 13, 2015 | Post #10 | viiii1969
Join date: Jul 2015 | Post subject: crew locksmith dot com
A lock is designed to keep crime out, but sometimes these devices
actually lure criminals inside. It has happened to just about everyone
that they locked themselves out of their car, home or workplace and not
everyone carries a set of spare keys so then the only way out is to call
a locksmith, who will come and unlock the doors for a certain fee. All
of this is simple enough, the problem occurs when the locksmith is a
phony one. | |
Thu Jul 16, 2015 | Post #11 | JAI PRAKASH
Fri Jul 24, 2015 | Post #12 | JAI PRAKASH
Wed Aug 05, 2015 | Post #13 | Jaswinder
Wed Dec 16, 2015 | Post #14 | Richard M. Pina
Join date: Dec 2015 | Post subject: What are special types of flooring?
Veru informative article!! | |
Tue Mar 01, 2016 | Post #15 | Larry
Join date: Mar 2016 | I have gone through the article. Well explained different types of flooring. Expecting more good posts from you. | |
