Home -> Forums -> Construction -> Start Construction -> specifications of building materials used in construction industry
Fri Aug 28, 2015Total posts : 3
Star Koziba Leladi
Star Koziba Leladi
Topic: specifications of building materials used in construction industry
can anyone help me on the list of materials used in construction and their specifications..
Mon Aug 31, 2015Post  #1
       There are more than 100 items used in the building construction. It is not possible to give all these here. Some of main items required during construction given in RAW MATERIAL in the website gharexpert.com.you should purchase civil engineer code book for specification.
Tue Sep 01, 2015Post  #2
Ask step by step as its a big list.
Sun Sep 06, 2015Post  #3
sanjay agarwal
sanjay agarwal
If you are making a house , preparing a list of all materials now will be a
wasted exercise.
You need only a map and design to start with.
Till your brick work and RCC roofing only 4-5 major materials are
important.
1  Steel Bars
2. Cement
3. Dust
5. Mortar
6. Bricks
These are all locally procured.
Later as you approach a requirement , based on your budget and taste
you will need to find what to buy.
I can help you in this. Pls ctc me at 9643450696.
2511
3304
GFRC Construction
10900
Last answer on 2/8/2021 2:14:37 AM. by John. Forum started by karthik
3559
Cost of construction
Last answer on 3/19/2013 11:44:19 AM. by S L Gupta (Civil Engg). Forum started by saurabh ramya
2390
BUILDING MATERIAL RATES & PETTY JOB RATES
Last answer on 5/15/2013 12:16:14 PM. by GULSHAN RAI GULATI. Forum started by GULSHAN RAI GULATI
2897
2415
can u give me the specifications of material shown in this picture and appox. ar
Last answer on 7/3/2019 12:31:26 AM. by Ajit Tareeka. Forum started by romaadhikari
2557
3257
2121
underground water tank
2703
Last answer on 12/31/2020 2:39:32 AM. by hauwa. Forum started by vidhiinteriors
2814
Last answer on 12/31/2020 2:39:26 AM. by Shally. Forum started by kalpana
3648
Living Room Ceiling
Last answer on 2/9/2021 5:22:05 AM. by Hikkler. Forum started by sheaikh mohd abid
2831
How do you get this high gloss finish..what is the material used
Last answer on 2/7/2010 8:59:56 AM. by ranjeetsaini. Forum started by vinita
2871
what material is being used in all these
Last answer on 7/4/2020 12:22:16 AM. by anish. Forum started by CV Bala
its good.i would want to knw about the materials used for cabints
Last answer on 7/29/2010 2:44:52 PM. by vimal. Forum started by shreya
2112
wich material using in flooring
Last answer on 10/21/2010 11:27:03 PM. by Gunjan Utraja. Forum started by Ranjit Shirke
2219
wich material using in false celling
Last answer on 10/21/2010 11:28:04 PM. by Gunjan Utraja. Forum started by Ranjit Shirke
3296
3309
2133
2059
Comparison
Hard
Gray
Gray Cement
Do you know the strength of a building depends on the quality of cement? Cement/ Gray cement is one of the most import..
Specification of Water
Clean and clear water is quite suitable for construction work.
Sanitary
Cedar Wood
