Home -> Forums -> Vastu -> Drawing Room -> staircase for commercial
Sun Mar 16, 2014Total posts : 1
Ankur
Ankur
Topic: staircase for commercial
i have a commercial plot facing west and south and want to build double storey shop along with basement. please tell me where to build staircase without covering fronts.
Tue Mar 18, 2014Post  #1
1671
staircase for commercial plot
Last answer on 3/18/2014 12:24:11 PM. by S L Gupta (Civil Engg). Forum started by Ankur
1780
Please give me commercial bulding plan 35feet front* 160feet deep space
Last answer on 7/8/2014 11:47:55 AM. by seema tyagi. Forum started by Asif Inamdar
2768
Lawn Care Tips
Last answer on 7/3/2020 10:35:08 PM. by Tom Lendis. Forum started by abhishek pal
1870
I want knowledge about commercial interior project...is there any refreance like
Last answer on 8/5/2015 4:39:43 AM. by JAI PRAKASH. Forum started by sandeep yadav
1488
I have plot in Coiambatore, I wish to construct a Commercial building Stilt park
Last answer on 5/22/2017 1:38:27 PM. by S L Gupta (Civil Engg). Forum started by R. Ramasubramanian
2245
2172
Commercial Drywall: What's the difference?
Last answer on 12/16/2016 12:55:28 PM. by S L Gupta (Civil Engg). Forum started by Shannon
1473
1646
is there any problem having a toilet under the staircase inside the house?
Last answer on 4/5/2017 1:01:34 PM. by S L Gupta (Civil Engg). Forum started by aditya mishra
1297
Staircase for South facing site
Last answer on 6/12/2018 11:55:12 PM. by S L Gupta (Civil Engg). Forum started by G Narayana Raju
1854
Last answer on 12/24/2015 4:17:23 AM. by JAI PRAKASH. Forum started by paramesh
2278
Last answer on 8/25/2011 4:35:06 PM. by Naveen. Forum started by supraja
2654
2346
remedies for anticlockwise staircase in Brahmasthana
Last answer on 12/30/2011 7:42:54 PM. Forum started by vibin
2422
my staircase starts from NE corner
Last answer on 9/11/2020 10:43:05 PM. by M Jindal. Forum started by pankaj
2859
Last answer on 12/9/2010 11:06:35 PM. by S L Gupta (Civil Engg). Forum started by kapil
2020
for south facing site external staircase should be in whitch direction
Last answer on 12/12/2010 1:15:56 AM. Forum started by KALAIVANI
2872
Position of staircase as per vastu
Last answer on 2/3/2011 10:41:29 AM. by nith_piyush. Forum started by Bhovotosh Deb
15611
3677
3088
2317
2346
3406
2266
5121
1845
7104
2555
2144
1724
1834
2074
5822
2676
7307
7539
2705
Staircase
Staircase railings
Stairs
Stairs Design
How to Design Stairs?
