staircase leading to terrace
Sat Aug 23, 2014
ADINATH
Topic: staircase leading to terrace
most internal staircases leading to a flat terrace require the construction of a room at the top where the staicase meets the terrace.
Is there an alternative design ...such as may be a trapdoor at the end?
Members kindly suggest ideas keeping in mind that the arrangement should be practical ,easy to use ,secure and keep out rain water.
Sun Aug 24, 2014
Post subject: staircase leading to terrace
Hello..! Adinath.... It is not practical ...regards.
Mon Aug 25, 2014
I think you are talking about a Mumti on the terrace. If Yes, then that is very much required.
Thu Aug 28, 2014
ADINATH
dear members thanks for replying...I guess Ill hav to go for external staircase.
2666
can anybody suggest me the led or lcd location on the L shape drawing/dinning ro
Last answer on 6/6/2012 7:59:32 PM. by
Harmender Singh
2449
what does the vastu says for staircase position that is used from first floor to
Last answer on 4/5/2012 7:27:08 PM. by
ABID ALI
k.guru prasath
1783
We don't have stairs leading to terrace, sometimes it is very difficult to go up
Last answer on 9/23/2014 3:42:18 PM. by
Akshata Rao
Akshata Rao
2176
I want to cover my terrace because of leakage problem during rains.If i want to
Last answer on 9/12/2014 9:53:08 PM. by
Akshata Rao
2505
i have a staircase in the northeast direction of the building that i live in.we
Last answer on 5/28/2013 11:36:44 AM. by
GULSHAN RAI GULATI
aishwarya
3315
best ceiling LED LIGHTS FOR NEW HOME IN HARYANA CONSIDERATION VOLTAGE FLUCTUATIO
Last answer on 7/4/2020 3:58:43 AM. by
Sushant
sanjeev tiwari
2230
Last answer on 11/20/2011 3:59:23 PM. by
sathish
vani ravikumar
3134
Door for First Floor sitout
Last answer on 7/3/2020 11:22:36 PM. by
vinod singh
yasothabalanr
2880
Terrace water proofing
Last answer on 7/13/2020 12:26:53 AM. by
ravi pachipala
2284
Last answer on 9/29/2014 12:34:55 PM. by
Sanjay Gupta
3106
Last answer on 8/27/2015 6:46:22 PM. by
3741
PLEASE TELL ME THE DIFFRENCE BETWEEN B.B.COBA AND IPS TYPE OF WATERPROOFING FOR
Last answer on 7/30/2014 9:22:58 PM. by
2624
where to keep pooja mandir in living room measuring 17X19sq feet with terrace in
Last answer on 3/24/2012 2:53:23 PM. Forum started by
srpatil
1781
Last answer on 7/4/2020 2:32:26 AM. Forum started by
shivam gupta
1525
Last answer on 1/28/2018 4:51:24 AM. by
Er.S.K.Jain
S.Nagarajan
1277
Staircase for South facing site
Last answer on 6/12/2018 11:55:12 PM. by
G Narayana Raju
1630
is there any problem having a toilet under the staircase inside the house?
Last answer on 4/5/2017 1:01:34 PM. by
aditya mishra
1458
Last answer on 12/26/2016 1:20:47 PM. by
2846
Last answer on 12/9/2010 11:06:35 PM. by
kapil
2451
Roof Garden
Staircase railings
Stairs Design
How to Design Stairs?
Roof Flashing
Is the ceiling of your house leaking? Apply roof flashing technique to prevent water leakage from the roof. Roof flash..
Solar Lighting
Solar lighting conserves energy and lowers the cost of energy consumption. It is renewable and infinite source of ener..
