Thu Nov 02, 2017
Seraj Ahmed
Topic: What is standard thickness or rod needed for RCC (dhalai)
Thu Nov 02, 2017
The diameter of MS Steel bar/ rod is calculated according to loading and span of the room. How ever for slab/ roof MS Steel bar of 10mm or 12 mm is generally used.
Last answer on 1/6/2022 11:48:27 PM. by
2196
Last answer on 11/13/2014 6:27:55 PM. by
Navaz
2701
Last answer on 5/17/2014 12:39:31 PM. by
gaurav
Yousuf khan
2862
cost of rcc slab
Last answer on 12/26/2013 11:30:08 AM. by
abdul wahid laskar
3830
Roof Beam
R.Roy
5196
ringwang
R.Roy
3966
Roof leakage
Last answer on 2/25/2013 11:42:01 AM. by
Structure drawing - Is it OK ?
Last answer on 6/4/2011 4:42:55 PM. by
P. Panchal
manjuks
11037
Last answer on 3/16/2021 12:44:03 AM. by
Mohan
1720
2669
Last answer on 7/2/2021 3:17:17 PM. by
B Thakar
minhaj sk
3169
Last answer on 3/14/2021 11:13:22 AM. by
venkatesan.pt.
2533
Need support regarding Beam steel design
Last answer on 1/7/2014 2:57:59 PM. by
Sunil Kumar
1627
Construction Cost for RCC Roof / SlabsI am constructing a house 25* 36. slab thi
Last answer on 11/6/2015 12:49:45 AM. by
sandeep
8637
Last answer on 7/23/2012 11:37:26 AM. by
dominate27
2979
Last answer on 8/17/2015 1:16:00 PM. by
jaydeep
2403
COSTING AND STRENGTH OF WALL
Last answer on 1/23/2016 8:45:03 PM. by
BYJU
2191
Brick Masonry Columns
Last answer on 1/14/2014 12:50:59 PM. by
Ahmed
Ahmed
2108
Floor thickness
Last answer on 9/5/2014 11:40:46 AM. by
ravi pachipala
267
Last answer on 11/7/2024 5:25:50 PM. Forum started by
Molvi Aftab Khan Ji
80
Last answer on 11/7/2024 5:25:49 PM. Forum started by
Molvi Aftab Khan Ji
28
Last answer on 11/7/2024 5:25:35 PM. Forum started by
Molvi Aftab Khan Ji
25
Last answer on 11/7/2024 5:25:34 PM. Forum started by
Molvi Aftab Khan Ji
30
Last answer on 11/7/2024 5:25:33 PM. Forum started by
Molvi Aftab Khan Ji
30
Last answer on 11/7/2024 5:25:32 PM. Forum started by
Molvi Aftab Khan Ji
29
Last answer on 11/7/2024 5:25:31 PM. Forum started by
Molvi Aftab Khan Ji
27
Last answer on 11/7/2024 5:25:30 PM. Forum started by
Molvi Aftab Khan Ji
27
Last answer on 11/7/2024 5:25:29 PM. Forum started by
Molvi Aftab Khan Ji
28
Molvi Aftab Khan Ji
24
Last answer on 11/7/2024 5:25:28 PM. Forum started by
Molvi Aftab Khan Ji
24
Last answer on 11/7/2024 5:25:27 PM. Forum started by
Molvi Aftab Khan Ji
21
Last answer on 11/7/2024 5:25:26 PM. Forum started by
Molvi Aftab Khan Ji
30
Last answer on 11/7/2024 5:25:25 PM. Forum started by
Molvi Aftab Khan Ji
21
Last answer on 11/7/2024 5:25:24 PM. Forum started by
Molvi Aftab Khan Ji
30
Last answer on 11/7/2024 5:25:23 PM. Forum started by
Molvi Aftab Khan Ji
Last answer on 11/7/2024 5:25:22 PM. Forum started by
Molvi Aftab Khan Ji
27
Last answer on 11/7/2024 5:25:21 PM. Forum started by
Molvi Aftab Khan Ji
Last answer on 11/7/2024 5:25:20 PM. Forum started by
Molvi Aftab Khan Ji
23
Last answer on 11/7/2024 5:25:19 PM. Forum started by
Molvi Aftab Khan Ji
What is the standard thickness of glass for glass windows?
The standard thickness of glass
What is the thickness of PVC pipes and diameter for drainage ?
Thickness of PVC Pipes and various diameters for drainage are .........
