Fri Dec 21, 2012 | Total posts : 3 |
| Topic: start construction Steel use
I want to built house in plot size of 15’ * 30’ (parking + 4 floor) (extinction
of 3 feet in balcony) attached drawing on floor plan.
I want to know how much steel (tmt) used in each RCC
column/ pillar.
We want to use
8 nos 16 mm for 12” * 9” (upto parking + 1 & 2
floor after that 6 nos 16 mm ) in 5 pillar.
10 nos of 16 mm in corner pillar for extra strength.
4 nos 16 mm + 2 12 mm 9 for 9” * 9” pillar
8mm ring in 6” distant
in parking. After that 8mm ring in 8” distance.
Please suggest is this sufficient.
Sir please suggests should we use down column (latk beem) (4 nos 16 mm + 2 no 12 mm) in lenter or use flat
column (4 nos 16 mm).
Sir please suggests the ratio of cement concrete for pillar
& linter. And brand of cement. (PPC or OPC).
IR |
Mon Dec 24, 2012 | Post #1 | S L Gupta (Civil Engg)
When you are constructing a 5 story building with investing more than Rs 50 lacs than I did not under stand that after taking a plan from architect, you do not want a structural drawing from structural engineer who gives the position of coluns beams and slab with their sizes and the requirement of steel bars and also have concern about earth quack while designing. After getting structural drawing you feel that there is saving and safety is main concern.
Use OPC CEMENT and ratio of cement concrete should be 1;1.5;3. The concrete should be mechenically mixed and vibrated.See gharexpert web site construction section for more knowledge about construction. | |
Mon Dec 24, 2012 | Post #2 | mollybisa
Carbon and other elements act as a hardening agent, preventing dislocations in the iron atom crystal lattice from sliding past one another. Varying the amount of alloying elements and the form of their presence in the steel (solute elements, precipitated phase) controls qualities such as the hardness, ductility, and tensile strength of the resulting steel. Steel with increased carbon content can be made harder and stronger than iron, but such steel is also less ductile than iron.
Alloys with a higher than 2.1% carbon content are known as cast iron because of their lower melting point and good castability.[1] Steel is also distinguishable from wrought iron, which can contain a small amount of carbon, but it is included in the form of slag inclusions. Two distinguishing factors are steel's increased rust resistance and better weldability. | |
Mon Dec 24, 2012 | Post #3 | mollybisa
Iron is found in the Earth's crust only in the form of an ore, usually an iron oxide, such as magnetite, hematite etc. Iron is extracted from iron ore by removing the oxygen and combining the ore with a preferred chemical partner such as carbon. This process, known as smelting, was first applied to metals with lower melting points, such as tin, which melts at approximately 250 and copper, which melts at approximately 1,100.
Articles that might interest you! | | Uses of Granite in Building Construction In today’s construction industry, Granite is one of the major ingredients. Granite is used in verity of locations and .. | | Are you constructing a cupboard, Learn the difference between wood-only and wood-brick cupboards Cupboards construction using different materials: Brick and Wooden Cupboards, Just Wooden Cupboards, Mesh Cement and W.. | | Guidelines while Starting Construction The whole building should be constructed at one time to avoid settlement in any portion of the building. | | Cupboards construction using different materials: Brick and Wooden Cupboards, Just Wooden Cupboards, Mesh Cement and Wood Today lots of options are available for cupboard construction. In the article here we will discuss all the material op.. | | Hard wood Characteristics and application Hard wood is one of the major resources for wooden flooring today. You must know hard wood specification before buying.. | | How to ensure weight of steel members? Before you purchase mild steel members for construction of your house, you must know weight and cost of steel members .. | | Type of Steel Bars Different steel bars are recommended for their relative tensile stresses.Steel bars are major components of constructi.. | | Mild Steel Bars in Cement Concrete Mild steel bars in reinforced concrete are one of the exceptional building materials. Reinforced concrete requires ver.. | | Skylight Types, Design and Uses Skylights or roof windows not only provide ventilation solution but also enhance the beauty of your home. By installin.. | | Types of Cement The strength of a construction depends upon the cement of superior quality.
| | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
