std. size of door
Fri Jan 03, 2014Total posts : 3
Rohit Patel
Rohit Patel
Topic: std. size of door
What is std . size of door and which materiel should be?
Mon Jan 06, 2014Post  #1
Dear Rohit
       The size of door as per room requirement.
 As for toilet use 2'-6'' x 6'-9'' door for room the sizes are 3', 3.5feet wide and 6'-9'' or 7-00 high. In some cases height taken as 8'-6'' or 9' with 1'-6'' or 2 feet as ventilator.
Mon Jan 06, 2014Post  #2
Rohit Patel
Rohit Patel
Dear Mr. Gupat,
what is std height of ceiling  for a flat apartment.
Mon Jan 06, 2014Post  #3
Dear Rohit
       The  height for flat should be 3meter or 10feet it has some flexibility.
Window Size
Last answer on 1/3/2014 1:07:20 PM. by S L Gupta (Civil Engg). Forum started by Rohit Patel
1336
Std. Size of BedRoom
Last answer on 2/18/2014 12:37:17 PM. by S L Gupta (Civil Engg). Forum started by Rohit Patel
2528
price for brass door and what is the size
Last answer on 7/3/2020 11:36:39 PM. by jyoti. Forum started by amin
2586
What are the size available What about strength of main door price details
Last answer on 11/18/2013 3:35:39 PM. by S L Gupta (Civil Engg). Forum started by padma
2432
interior 4 living room entrance (door) 4m east size 12ft*14ft
Last answer on 10/19/2021 2:25:10 AM. Forum started by nisar
1784
Plot .23×50 size West .....house door
Last answer on 7/2/2020 9:45:51 PM. by S L Gupta (Civil Engg). Forum started by siddharth mishra
1400
Hello,can we make double door from flush door. door size is 38.3x 79.4 and neare
Last answer on 2/8/2017 2:23:00 PM. by S L Gupta (Civil Engg). Forum started by Ashok
1603
Curtain size
Last answer on 7/6/2016 11:16:37 AM. by S L Gupta (Civil Engg). Forum started by K. Basu
5277
if anybody have good main door frame models pics?,prefer rectagle model size 210
Last answer on 8/9/2013 10:15:39 AM. by GUNA. Forum started by rense
1819
Please let me known price of doors. Also do you do all sizes.
Last answer on 5/9/2010 2:44:32 AM. by priya. Forum started by jazz
2422
Door Hinghes
Last answer on 12/28/2012 11:37:54 AM. by S L Gupta (Civil Engg). Forum started by Unnikrishnan
3679
about size of chowkets
1672
Hi, two questions i have.1) my door lengths are 78.6 and 79 inches .Flush door s
Last answer on 2/8/2017 2:32:54 PM. by S L Gupta (Civil Engg). Forum started by Manish Chugh
3116
1745
1256
1911
chick door
1630
2293
Which places are appropriate for flush doors in home?
Last answer on 7/3/2020 11:16:11 PM. by JAI PRAKASH. Forum started by kishore jain
285
85
29
26
32
31
30
28
28
29
25
25
22
31
22
31
31
24
Right size cupola
What is binding wire
