steel
steel
Wed Apr 10, 2013
Topic: steel
hi,
Available brand in market is tata itiscon, jindal, kamdhenu, morya,buland. rathi which one is good steel for constitutions either TOR, Ribbed, or TMT steel and tata and jindal have high price then morya and local brand only because of brand name or there is difference of material in it.
1-mild steel or deformed steel should be used for construction as point of view of durability,strongness?
2-which is costlier mild or deformed steel, all manufacturer makes both this two type?
Thu Apr 11, 2013
Dear Paresh
Use deformed steel bars in RCC which has more strength and more bonding grips.Tata is the best in quality. Spare some time read web site gharexpert.com where in construction section you will find lot about construction. For steel bars visit sub section STEEL of construction. See link below.
http://www.gharexpert.com/articles/Steel-1021/Type-Steel-Bars_0.aspx
Thu Apr 11, 2013
Post subject: DEFORMED OR SCRAP
Dear gupta sir,
is deformed and steel made up through scrap is same? .
deformed tata steel is also available ?
Fri Apr 12, 2013
Dear paresh
Deformed, Tor or ribbed these steel bars are made from good quality steel, if test these steel, that are not brittle in nature. From old scrap local mill make steel bars which is very hard and brittle in nature, 8mm 10 mm steel you can test by your hand by binding the piece.
4330
Last answer on 3/15/2011 6:15:21 PM. by
Mohini Sharma
kanwer sajjad
2898
RCC Roof
Last answer on 7/4/2020 12:19:59 AM. by
ARVIND GOYAL
2216
Last answer on 4/21/2015 11:35:52 AM. by
Last answer on 7/26/2021 2:26:58 AM. by
COLUMN AND STEEL DESIGN
Last answer on 1/9/2021 12:01:44 AM. by
Kaleemullah
4939
Kaleemullah
3721
Last answer on 2/22/2021 2:25:37 AM. by
Mohiuddin
4949
Last answer on 6/24/2021 1:12:48 PM. by
sunny420
2248
Last answer on 9/23/2012 3:04:33 PM. Forum started by
rizwan
3009
Last answer on 6/26/2019 10:25:56 PM. by
kalpana
2669
Last answer on 10/18/2010 9:42:39 AM. by
kiran
sachin
2395
Tips for Aluminum Paint
Last answer on 1/16/2011 2:41:59 PM. by
Swati Sharma
Ar.chitra Tibrewal
2910
Last answer on 5/1/2014 1:04:48 PM. by
Ahmed
mangesh yenwaskar
2087
what is the density of stainless steel per cum
Last answer on 10/17/2016 9:14:46 PM. by
4126
Last answer on 8/16/2013 4:38:03 PM. by
jk
2327
Last answer on 9/23/2013 11:44:05 AM. by
HYDER ALI
2163
R.C.C 1:2:4
Last answer on 3/18/2014 1:14:13 PM. by
ijazulhaq
1835
chick door
Last answer on 2/23/2022 6:04:01 AM. by
Nimit Panwar
1821
Last answer on 7/3/2020 11:35:37 PM. by
Ganpat B Chaudhary
Steel Roofing
