Home -> Forums -> Construction -> Steel -> steel
steel
Sat Sep 14, 2013Total posts : 1
Abhi
Abhi
Topic: steel
Kindly suggest which steel grade ( Fe415 , fe500 or fe500D) will use for residential purpose or Roof slab ,   Beam and  Pillar
Which one cost is effective and strength .
Sat Sep 14, 2013Post  #1
Dear Abhi
       For RCC work use Fe 500 grade see the link below
http://www.gharexpert.com/articles/Steel-1021/Type-Steel-Bars_0.aspx
Steel-Construction Questions (40)
4314
2871
RCC Roof
2205
15537
4927
COLUMN AND STEEL DESIGN
4927
3187
steel
3708
4115
4933
2315
2154
R.C.C 1:2:4
Last answer on 3/18/2014 1:14:13 PM. by S L Gupta (Civil Engg). Forum started by ijazulhaq
2378
Tips for Aluminum Paint
Last answer on 1/16/2011 2:41:59 PM. by Swati Sharma. Forum started by Ar.chitra Tibrewal
2995
2656
2234
1827
chick door
1814
1874
Steel Erectors
2847
Steel calculation
2669
steel requirment
15537
1983
Residential complex
4335
RCC Columns
3222
7439
Bar Bending Schedule Software
2511
steel
29835
2599
9338
2188
Current iron rod price
2594
1874
Steel Erectors
2366
3255
13666
overlap length to steel
2148
2525
Type
HSD
Precautions
Steel
Steel Roofing
TMT
