Home -> Forums -> Construction -> Steel -> steel formula
steel formula
Mon Apr 07, 2014Total posts : 4
shaik khaja nayab rasool
Topic: steel formula
hai..sir what is formula for calucating the steel weight..
                          1) rounded bars
                           2) square bars
Tue Apr 08, 2014Post  #1
M S Steel Round & Square Bar
 S. No.  Dia. of Steel Bar (mm) Weight per meter
Round Bar                             Square per meter
Kg.                                           Kg.
 1. 6 0.22                                          0.28
 2. 8 0.39                                          0.50
 3. 10 0.62                                          0.78
 4. 12 0.89                                          1.13
 5. 16 1.58                                          2.01
 6. 20 2.46                                          3.14
 7. 25 3.85                                          4.91
M S Angles
 S. No
 Size of Angle
mm.
 Weight per meter
Kg.
 1. 20x20x3  0.9
 2. 25x25x3 1.1
 3.
30x30x3
30x30x4
1.4
1.8
 4. 35x35x3 1.6
 5. 35x35x4 2.1
 6. 40x40x6 3
 7. 40x40x3 1.8
 8. 40x40x4 2.4
 9. 40x40x5 3
 10. 40x40x6 3.5
 11. 50x50x3 2.3
 12. 50x50x4 3
 13. 50x50x5 3.8
 14. 50x50x6 4.5
R S Joist/Girder
 S. No.  Size of Girder
Weight per meter
Kg.
 1. 150x50 7.1
 2. 150x80 14.2
 3. 175x50  8.1
 4. 175x90 16.7
 5. 200x60 9.9
 6. 200x100 19.8
 7. 225x80 12.28
 8. 225x100 23.5
 9. 250x200 40.9
 10. 300x150 37.7
 11. 300x200 48.1
T- IRON
 S. No. Size of T-Iron   Weight per meter
Kg.
 1. 75x150 15.3
 2. 100x200 20
 3. 125x250 27
 4. 150x250 29.42
 5. 100x50 8.1
 6. 75x80 7.1
 7. 100x100 12.7
 8. 75x50 3.5
corner corner
corner corner
corner corner
One wall compact stainless steel kitchen
Modular kitchen design in wooden laminates with stainless steel Cooking range and hood
Modular kitchen design in wooden laminat...
Steel Railing,SS Railing, Handrail,Glass Railing
Tue Apr 08, 2014Post  #2
Post subject: formula..
thank u sir for ur respond but i want the exact formula..like d2/162 (rounded bars) can u give me formula for square bars..
Sun Apr 13, 2014Post  #3
Hi Rasool: Just as weight of round bars in kg/mtr is calculated as d(squared)/162 where d is in mm; the same formula when applied for square bars is d(squared)/127 where d = thickness of square bar, is in mm only.
I hope it helps.
Wed Apr 16, 2014Post  #4
thank u sir it really help me.
Steel-Construction Questions (39)
2129
what is the formula for calculating wt/ m for sq alluminium bars
Last answer on 12/4/2021 9:11:25 PM. Forum started by SANJAY DUSANE
15582
4330
2216
2898
RCC Roof
4939
COLUMN AND STEEL DESIGN
4939
3206
steel
3721
2248
4949
2394
Tips for Aluminum Paint
Last answer on 1/16/2011 2:41:59 PM. by Swati Sharma. Forum started by Ar.chitra Tibrewal
3009
2669
2087
what is the density of stainless steel per cum
Last answer on 10/17/2016 9:14:46 PM. by JAI PRAKASH. Forum started by SANJAY DUSANE
2163
R.C.C 1:2:4
Last answer on 3/18/2014 1:14:13 PM. by S L Gupta (Civil Engg). Forum started by ijazulhaq
2910
4126
2327
2684
steel requirment
15582
1992
Residential complex
4367
RCC Columns
3238
7479
Bar Bending Schedule Software
2521
steel
29941
2612
9362
2259
Current iron rod price
2605
1885
Steel Erectors
2382
3266
13772
overlap length to steel
2160
2539
Type
HSD
Precautions
Steel
Steel Roofing
TMT
Specification of Steel
