Home -> Forums -> Construction -> Steel -> steel requirment
steel requirment
Fri Oct 21, 2011Total posts : 3
vijaygutti
vijaygutti
Topic: steel requirment
I am planning for a 2000sqft house. How much steel is required?
Mon Oct 24, 2011Post  #1
Dear Vija
          The quantity of steel is depend on the structural design, weather it is frame work or not and steel quantity also depend upon the span of the beam and slab.
Sun May 06, 2012Post  #2
skziro
skziro
Post subject: Steel size(dia.)
           What will be Steel size(dia) of Pillar,Tie beam and Linter,Roof beam in 4th story building ?
Sun May 06, 2012Post  #3
skziro
skziro
           What will be steel size of Tie beam(on plinth level) in 5th story RCC building ?
2811
IN independent house - min how much rcc thk required and re informcement steel spacing and size of steel
Last answer on 3/1/2013 6:22:20 AM. by Maharshi. Forum started by tkalaiva
4330
15582
2216
2898
RCC Roof
1240
how much it cost for total 66 sqmt RCC, the area include roof 45.12 m3, coulmn 5
Last answer on 12/26/2016 12:38:13 PM. by S L Gupta (Civil Engg). Forum started by ahmed
4939
COLUMN AND STEEL DESIGN
4939
3206
steel
3720
4949
2247
2669
2393
Tips for Aluminum Paint
Last answer on 1/16/2011 2:41:59 PM. by Swati Sharma. Forum started by Ar.chitra Tibrewal
3009
2087
what is the density of stainless steel per cum
Last answer on 10/17/2016 9:14:46 PM. by JAI PRAKASH. Forum started by SANJAY DUSANE
2909
4126
2327
15582
1991
Residential complex
4366
RCC Columns
3238
7478
Bar Bending Schedule Software
2521
steel
29941
2611
9360
2256
Current iron rod price
2604
1884
Steel Erectors
2381
3265
13772
overlap length to steel
2159
2538
Type
HSD
Precautions
Steel
Steel Roofing
TMT
Specification of Steel
