Mon Oct 06, 2014Total posts : 2
Topic: what are the steps for fixing/ laying wooden flooring
Mon Oct 06, 2014Post  #1
Plz check the link:
http://en.wikipedia.org/wiki/Wood_flooring
Tue Oct 07, 2014Post  #2
http://www.gharexpert.com/articles/Wooden-flooring-1426/Installation-Precautions-Wooden-Flooring_0.aspx
http://www.gharexpert.com/articles/Wooden-flooring-2280/How-to-level-concrete-sub-floor-before-installing_0.aspx
http://www.gharexpert.com/home/new_categorylist.aspx?PL=2&CATID=1349
1684
Last answer on 10/7/2014 11:37:58 AM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE
2490
is these lights fixed inside the wooden boxes?
Last answer on 3/3/2011 9:03:23 PM. by Nenni. Forum started by meenu
4736
3325
3563
Kitchen Pictures
Last answer on 8/28/2020 2:40:10 AM. by Swati Ray. Forum started by SUTANU RANA
2895
Terrace water proofing
2324
how wooden flooring is done
Last answer on 7/3/2020 11:14:47 PM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE
2097
what is wooden flooring and how it is done
Last answer on 10/6/2014 12:54:01 PM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE
2002
Required PVC Wooden Flooring
Last answer on 10/18/2013 3:52:51 PM. by S L Gupta (Civil Engg). Forum started by Krishna Equytech
2740
Wooden Flooring
Last answer on 2/9/2021 5:39:37 AM. by Prakash Pandey. Forum started by atiq khan
1982
what are the different good wooden flooring options available...pl suggest
Last answer on 5/23/2011 10:12:30 PM. by S L Gupta (Civil Engg). Forum started by Reena
1608
Which colour of floor tiles should be fixed as per vasthu
Last answer on 3/14/2017 12:10:29 PM. by S L Gupta (Civil Engg). Forum started by Subbu
1706
What are the important steps of maintenance after installation of blended marble vinyl flooring?
Last answer on 6/25/2014 1:43:17 PM. by S L Gupta (Civil Engg). Forum started by chandrapalsen
2352
laying of roof
2786
what is this floor made up of?? can we put glass in the wooden floor?
Last answer on 12/31/2020 2:29:52 AM. by Deepti. Forum started by ranjit
2439
I want to replace my kitch rooms existing flooring by wooden floor.Any suggessio
Last answer on 11/8/2010 5:56:44 PM. by Snigdha. Forum started by Anirudh
3589
Per Sq:ft rate for flooring
3200
Ready Mix Concrete
Guideline for laying DPC
Door
Door and Window Frames
Check width and depth of the channel, the quality and size of the bricks for mechanical protection.Whether cable ident..
