structure work
structure work
Thu Aug 18, 2016
manish agarwal
Topic: structure work
Hi i am uploading house plan and structure drawing ..please suggest me its good or not..thanks
40x60 first floor plan -02.pdf on Thu Aug 18, 2016,
40x60 Ground floor plan -01.pdf on Thu Aug 18, 2016,
DETAILS-1.pdf on Thu Aug 18, 2016,
EXCAVATION PLAN-2.pdf on Thu Aug 18, 2016,&n
Sat Aug 20, 2016
Dear Aggarwal
It is good plan.
2371
structure work
mamtagarg
manish agarwal
1672
structure work
Last answer on 8/20/2016 12:43:48 PM. by
manish agarwal
14592
Last answer on 7/3/2020 10:42:37 PM. by
mpkumar
mpkumar
2330
Last answer on 7/3/2020 10:02:44 PM. by
mohammed yousuf
3397
Bathroom Cleaning Tips
Last answer on 6/10/2019 1:04:58 AM. by
jaswinder Singh
Nitesh Patel
2115
Structure proof checking
Arnab Ghosh
2210
Last answer on 9/14/2021 5:43:01 AM. by
neha
1820
Last answer on 7/3/2020 11:35:37 PM. by
Ganpat B Chaudhary
2616
COLUMN nd LOAD BEARING
Shivaraj
Shivaraj
2196
method of road structure, step wise detail caculation of material
Last answer on 3/15/2011 6:14:15 PM. by
kanwer sajjad
kanwer sajjad
2066
Can u please tell me what should be the form and structure of a drawing room
Last answer on 9/19/2011 8:37:44 PM. Forum started by
Ruchi Shrivastava
3106
Last answer on 10/5/2020 10:59:59 PM. by
DEVANSU
4443
lobar work quantity
Last answer on 2/21/2021 12:21:16 AM. by
D A VRAO
shaik khaja nayab rasool
3001
House Estimation Breakdown
Last answer on 7/3/2020 10:42:10 PM. by
Ayub Khan
Ayub Khan
2722
Cost of RCC
Last answer on 4/4/2014 2:22:58 PM. by
Vasanth
2593
JOINERY WORKS
Last answer on 12/11/2013 11:18:00 AM. by
Last answer on 12/26/2014 1:00:45 PM. by
Last answer on 1/23/2022 3:40:26 AM. by
Last answer on 12/26/2014 12:58:07 PM. by
Checklist for Painting Work
