Home -> Forums -> Construction -> Start Construction -> suction pipe length for sump motor
Fri Oct 01, 2010Total posts : 0
manjuks
manjuks
Topic: suction pipe length for sump motor
I  am getting one more additional water storage sump tank constructed in the portico area  for storing about 7500 ltrs of water. I am using existing sump (3000 ltrs) motor of 1/2 hp to pump water.
I intend to  replace the 1/2 HP Suguna pump motor with 1 hp motor and use the same for pumping water from both tanks but one at a time. I wanted to know whether the motor  can  pump water from the addln tank if the suction pipe length is 40 ft. The existing pump is nearer to existing tank(suction 10 ft).What is the max pipe length  a motor supports for good suction nad discharge ? Pl clarify thro return e mail  mnathks@gmail.com
from
k s manjunatha
1844
2180
Last answer on 12/31/2020 8:58:35 PM. by S L Gupta (Civil Engg). Forum started by Joseph Santhosh
2084
2372
Sewage and drainage lines
2394
Specification of Water
Last answer on 12/31/2020 2:40:46 AM. by SHEIK. Forum started by AYYAZ SHAIKH
2100
suppose i take all water pipes through sunken area along the length and breadth
Last answer on 7/23/2011 2:18:10 AM. Forum started by D.Ramachandran
1422
Basic Details:I am going to dig a borewell for 3 storied house construction and
Last answer on 1/17/2018 11:49:03 PM. by S L Gupta (Civil Engg). Forum started by Shekar Nair
1980
PLUMBING
2917
2215
sewage pipes
13483
3475
2526
what happens when sump comes at north east corner inside the room
Last answer on 7/3/2020 10:54:04 PM. by S L Gupta (Civil Engg). Forum started by vedamurthy
10089
3350
1618
West face House, can we construct North west side face sump
Last answer on 7/4/2020 2:50:11 AM. by S L Gupta (Civil Engg). Forum started by G.Mallikarjuna
9160
2156
can waste pipe pass the inner maingate ?
Last answer on 12/31/2020 2:33:37 AM. by S L Gupta (Civil Engg). Forum started by ankit gupta
3252
2443
3266
3278
4425
3970
2188
2695
4206
5160
2370
2290
1992
2442
2112
3191
2041
12509
2158
2007
2722
Vastu for Water Tank
Sewerage
Sewerage & Plumbing System
General
Various
