Brick work
for superstructure esstimate
Tue Aug 13, 2013
Bs Dhiman
Topic: for superstructure esstimate
Respected S L Gupta sir,
i have some confeusion in s.structure.sir in 1000 sqft.your estimate is 30 beg of cement,8 cum sand nd 14400 bricks in ration 1:7 . nd sir in 1000 sqft 14400
bricks.what i got estimate 22000 to 23500 bricks on many house plan.where i am worng sir? please help me in this way sir.
Sat Aug 17, 2013
Dear BS
The estimator gives the rough cost estimate based on general house plan.Now suppose you make two nos room 10'x10'. covers 200 sqft area. Then there is 7 nos 9'' wall i.e. 70feet.In other case if you want to construct 20'x20' size room covers the area 400 sqft and wall length is 4x 20= 80 sqft. In this case area increase is double i.e. 100% increse but wall length increase is 14%. For calculation of bricks you calculate the cubical contents i.e. length x width x height as 10' x 9/12x 12 = 90 cft or 2.54 cum x 480 bricks. Do like this you will find solution. Any more information you are welcome.
Brick work-Construction Questions (29)
2075
how much will it cost for 2 floors superstructure,
Last answer on 7/19/2010 8:31:02 PM. by
harbans singh sekhon
N A.LAWAY
12997
HOW TO CALCULATE THE REQUIRED QUANTITY OF BRICKS, CEMENT AND STEEL
Last answer on 7/31/2011 12:54:31 PM. by
sanjay
2819
Super Structure construction
Last answer on 9/25/2020 4:33:02 AM. by
aryan
1867
Can anyone suggest the breakup ratio percentage cost like up to plinth beam, up
Last answer on 1/2/2021 5:27:29 AM. by
Shaik ibrahim
4051
RCC Column
Last answer on 10/22/2013 4:25:37 PM. by
Swarup
2120
Rcc Column construction (250x300 with 6-12dia. rod) for 2storied residentiial bu
Last answer on 11/12/2012 3:37:38 PM. by
Swarup
2709
Rcc Column construction (250x300 with 6-12dia. rod instead of 4-16dia.) for 2sto
Last answer on 12/6/2012 2:41:14 PM. by
Swarup
1893
New construction/ estimate
Last answer on 9/15/2014 4:16:22 PM. by
karthik
karthik
1515
help
Last answer on 8/6/2020 2:29:47 AM. by
sushantsah
3668
wals
shabbir ali
3262
compound wall
Last answer on 7/20/2021 1:24:04 AM. by
Satish Pingulkar
21869
Last answer on 7/3/2020 11:10:01 PM. by
Sambasiva Rao Ravuri
3279
Bedroom Wardrobes information
Last answer on 7/3/2020 9:26:49 PM. by
Meenakshi
2244
Last answer on 5/15/2017 1:39:35 PM. by
mknmohamed
2205
Last answer on 5/2/2017 5:25:23 PM. by
pramod
1494
Last answer on 1/16/2017 3:10:03 PM. by
1965
Last answer on 12/6/2016 1:58:54 PM. by
1732
2223
Last answer on 11/3/2016 11:03:14 AM. by
atulbelokar
2523
1501
Last answer on 10/29/2016 2:54:11 PM. by
Er.S.K.Jain
1907
Brick or ACC block
Last answer on 10/7/2016 4:31:32 AM. by
gpeter
gpeter
2024
1653
Last answer on 9/13/2016 2:59:02 PM. by
1702
4680
Brick wall on RCC slab
Last answer on 1/27/2016 11:56:55 AM. by
rajiv sharma
3928
Last answer on 7/28/2015 11:31:41 PM. by
nithin
2616
Last answer on 2/20/2015 6:00:27 PM. by
gurmeet singh
