Home -> Forums -> Construction -> Cement Plastering -> suppose if i want to purchase the blue print of the house can I purchase it?
Sun Jan 25, 2015Total posts : 0
aozzoa
aozzoa
Topic: suppose if i want to purchase the blue print of the house can I purchase it?
1371
sir pls send me the blue print
Last answer on 3/17/2016 11:29:59 AM. by S L Gupta (Civil Engg). Forum started by darshan
1925
I want purchased this plan pl contact my mob no 7577081958
Last answer on 2/22/2022 8:50:43 PM. by JAI PRAKASH. Forum started by Viratrana
1812
can a plot be purchased which a curving road in front giving it a kite shape
Last answer on 8/21/2015 12:18:38 PM. by Nageshwar. Forum started by virendra
1497
Last answer on 1/17/2015 11:33:39 PM. by JAI PRAKASH. Forum started by mohit kumar
2022
2146
Anyone know where the pendants can be purchased?
Last answer on 2/9/2022 1:49:41 AM. by jyoti. Forum started by jp medley
2192
Digital Door Viewers
Last answer on 7/26/2010 8:32:13 AM. by walt. Forum started by shashank
2260
should south west facing or west facing house to be purchased or not.what are th
Last answer on 9/6/2010 11:06:42 PM. by a vasanth kumar. Forum started by tanmay
2341
House contructed in the plot i have purchased has a southwest corner extension(p
Last answer on 12/11/2021 1:01:47 AM. by sabina vanjani. Forum started by subrahmanyam
2046
where can i purchase this solar ligts
Last answer on 12/9/2021 3:54:54 AM. Forum started by deepak
2329
purchased flat 10 yrs oldd , advise for renovation ,
Last answer on 7/4/2020 2:47:02 AM. by S L Gupta (Civil Engg). Forum started by alakh nath tiwary
1949
i purchased a corner plot 735 sf. i have need a good house design.
Last answer on 2/18/2012 11:33:17 PM. Forum started by gopeshwar
1789
from where can i purchase ?
Last answer on 1/12/2022 2:36:45 AM. Forum started by K K Awasthi
2654
I am purchasing a land 42x62 i want to make my home please give us idia
Last answer on 3/19/2012 3:31:22 PM. by Gunjan Utraja. Forum started by DILIP
1990
where we purchase railling material
Last answer on 10/4/2012 12:53:15 AM. by kamal. Forum started by Rajesh
3556
Last answer on 3/29/2017 9:32:31 PM. by Saurav anand. Forum started by K M N GANESH
1546
blue print
Last answer on 5/21/2013 11:44:27 AM. Forum started by srikrishna
3474
5352
main door vastu question
Last answer on 7/4/2020 3:03:42 AM. by geetika. Forum started by sujatha
2929
Plaster
2780
Plaster work
3046
Plastering
2003
PPC and OPC cement
11298
1870
suggest for exterior
7004
9157
1876
OPC and PPC cement
2157
2011
coarse aggregate
1826
Nice
2436
Gypsum Plaster Vs S/C Plaster
2173
Outer Plaster
2996
2734
putty work on walls
2236
2826
2032
Buying tips for Brick Blast
Buying
Buying tips for Cement
Tips to remember while purchasing a garden bench.
Buying tips for Bricks
Specification and Purchasing Guidelines of Marble Chips
Marble chips must be crushed mechanically and be free from marble dust and foreign matter.
Purchasing Guidelines for Marble and Granite Stone
Marble stone should be hard, free from any stain i.e. deep cut or mark on the surface.
