Sat Aug 14, 2010 | Post #1 | sabina vanjani
Please look at the below picture. The picture shows a cut in the NE. If thats what the problem is. You can fix looking glasses 2 inch wide in L shape as shown.
Sun Aug 15, 2010 | Post #2 | Neeraj Jain
Dear Valli,
There is no remedy, if NE corner cutting in the plot or a house. If NE corner cut from your plot, it is suggestable that you may leave the plot.
NE cutting in the plot or any house, that means there is no head on the body. If there is no head in the body, can it be possible the body will work in anyway?
Fri Aug 27, 2010 | Post #3 | Shanbaga Valli
Join date: Aug 2010 | Thank you Sabina and Neeraj for ur reponses. I am trying to work out both possibilities and see whether Sabina's solution gives any results. This is because our flat is our own house and it will take sometime for us buy or move into a rented house. | |
Sat Apr 13, 2013 | Post #4 | jayesh parmar
i have the same problem like urs
pls pls pls tell me the right solution which u might have got
my house too is owned
does that mirror thing works pls share dear friend
Thu Apr 18, 2013 | Post #5 | Pavan
Hello,
Just to add further, please find attached my suggestions and options.
Regards.
Wastu Wimarsh
Pavan Matkar | | | |
Tue Jul 22, 2014 | Post #6 | ram lal bijalwan
Join date: Jul 2014 | Post subject: north east part of plot is missing in L shape
I want to know what is the impact of this type of plot if i have such plot...in 150*64 feet is the plot dimension and at L shape it is 144*66 feetis this good for me or not please give suggestion | |
Wed Jul 23, 2014 | Post #7 | seema tyagi
Join date: Oct 2013 | Dear shanbaga valli, North East direction in the house is a very constructive direction and is a source of positive energy. Defect in Northeast direction will give negative impact in persons over growth living in that house.It
has been the experience of many people that the northeast corner cut
must be corrected first to avoid such problems. Where correction has not
been possible most of the people have rejected the plot itself.
If still you have any doubt please consult a vastu expert.
Thanks.
Thu Dec 18, 2014 | Post #8 | pal
Join date: Dec 2014 | Post subject: Question to Mr neeraj jain
hello there, I have a question for above house construction. When you are saying cutting East or North east ,are you talking about the plot or the actual house construction. I have a rectangular plot with no corners cut. I have constructed a house more or less the same drawn above where the northeast corner is left open. Is it a dosh? I thought leaving northeast open should be good in ishanya direction.i have more land further open on that direction as a rear garden.i would like a clarification as I am confused are we talking about the plot layout or actual construction of the house.looking forward for answers from other experts too. Thanks Pal | |
Fri Dec 19, 2014 | Post #9 | Nageshwar
Join date: Sep 2014 | Hi Pal, Basically it applies for both plot and house and secondly for your query, It [Iahanya] is considered dosh only when the roof / portico is not covered[Slab] on that area(portion). Leaving NE open means not related to structure [meaning is we should leave space between structure and compound wall(to that zone/direction)].Mirrors and other alternates wont solve the issue, we have to modify the structure.Any doubts further upload plan. Regards, Nageshwar (Vasthu Expert) | |
Sat Dec 20, 2014 | Post #10 | pal
thankyou Mr Nageshwer. I have a better understanding now. | |
Tue Dec 23, 2014 | Post #11 | Suni
Join date: Dec 2014 | Post subject: Both NE & SW corners are cut in Flat
Hello, What are the remedies to avoid ill-effects of having cut in both NE & SW? Please suggest the same. | |
Fri Jan 16, 2015 | Post #12 | JAI PRAKASH
Join date: May 2014 | Please consult with a Vastu Expert. | |
Wed Apr 29, 2015 | Post #13 | Harindra Nath
Join date: Apr 2015 | Post subject: no cut in the NE corner in the ground level & fo...
My house have no cut in the NE corner in the ground level & foundation, but can there be a cut in the North East Corner of the first floor? Now that I am planning to build on the first floor, I could save a whole lot of space. So, is it okay to have a cut in the NE corner only on the first floor. a spot on reply is highly appreciated.thankyou | |
Sat May 02, 2015 | Post #14 | Pavan
As mentioned in the above post by Mr. Nageshwar, Cuts are to be considered for the plot and or the foundation. In your case I suppose the foundation is a rectangle and you are planning to leave the NE space open on the first floor. If my understanding is correct, the approach is perfect.
Regards. Pavan Matkar
Wed Nov 02, 2016 | Post #15 | neo
Mera Ghar Builing Me 6th Floor Pe Hai. Mere Ghar Me Bhi NE Cut Hai. Waha Back Side Building Ki Lift Hai To Cover Karna impossible. SE Bhi Cut Raha Hai. SW Aur NW Bhi Cut Hi Hai Samjo. AB TAK Vastu Me Bahot Paise De Chuke. Par Ulta Condition Worst Hi Hai. Kya Kare?
North is Perfact Zero Degree.
Kisi Ne Kaha Ghar K 2 Part Kar Do Alag Alag. Wo Bhi Kiya. Kai Tarah K Yantra Lagaye.
Ab Lag Raha Hai K Koi Kuchh Nahi Kar Sakta.
Aap CHamatkar Kar Sakte Ho To Challenge Hai.
Wed Nov 02, 2016 | Post #16 | neo
Upar wali Post me mere ghar ka plan Diya Hai. Kindly Chk. & Discuss.
Agar Koi Cofidently Mere Ghar K Sare Vastu Dosh Clear Kar De To Me Fees Dene Ready Hu. Agreement Banega. Agar Problems Total Solve Nahi Huwe To Double Fees Aur Mera Ab Tak Ka Kiya Vastu Pe Ka Total Kharcha Return Dega To Me Fees Pay Karne Ready Hu. Aap Free Me Bhi kam karo par tod fod ab nahi karni. Karni Hai To Aap Apne Kharche Se Kare. Kyu K Usme Bhi Ab Tak Lakho Rupiye Dal Chuke. Par No Result.
Ghar Ka Plan Ek Bar Aur Post Kar Raha Hu.
Kuchh Discuss Karna Hai To am Ready.
Sun Nov 06, 2016 | Post #17 | Divya
Join date: Nov 2016 | Hello We have recently purchased a house and I am unable to understand that the plot has a cut in North east or slightly bend in that direction. kindly suggest me if it a cut or not and also suggest remedies. attaching the home plan. regards | | | |
Thu Dec 08, 2016 | Post #18 | debraj
Join date: Dec 2016 | Post subject: Please check vastu of my flat? Is it L shape or ...
Hi,I am going to buy a new flat. The flat has extended in Kitchen part. 2 bed room in one row and kitchen is on extend part on North side. Can i consider this as L shape or not? Flat diagram has attached for reference. | | | |
Sat Dec 10, 2016 | Post #20 | ritu
Join date: Dec 2016 | Post subject: I am attaching my floor plan. Wanted to know if ...
I can't tell if my floor plan has a cut or added part on the north east part of the floor plan on first floor. My door is towards the north and the north east door is the study. I am semi building the house and they had to go by some city standards and had to change the floor plan last minute. I didn't realize they were going to make the cut before we purchased the house. Now, what I wanted to know is would this be called a cut because the only thing in that room that sticks out is the closet. The room is in an awkward shape. | | | |
