there is lift or elevator in southwest side of my flat and staircase at north of
Mon Jun 03, 2013Total posts : 2
eswari
eswari
Topic: there is lift or elevator in southwest side of my flat and staircase at north of
there is lift or elevator in southwest side of my flat and staircase at north of northwest. is there any vastu dosh
Fri Jun 07, 2013Post  #1
geetika
geetika
The lift or elevator can be in the southwest side but it should not create any cut inside your flat in that direction.similarly if the staircase is outside your flat ,i.e if it is the common  staircase for all the flats it should not effect you.
Tue Jun 11, 2013Post  #2
Pavan
Pavan
Hello Eswari,
What floor do you stay on?
Is this a owned flat or a rental one?/ If rental/purchased what was the expericence of the old tenant?
How long you have been staying in this flat?
Any vastu advantage or disadvantage takes time to show effect
Regards.
Pavan Matkar
My flat north , east corner wall attached lift is it good or bad .?
Last answer on 4/17/2017 12:54:32 PM. by S L Gupta (Civil Engg). Forum started by Srinivas
2068
can lift can touch north wall of the flat
Last answer on 8/31/2017 12:24:48 AM. by S L Gupta (Civil Engg). Forum started by venkat
23750
lift or elevator on the north east wall of flat
Last answer on 2/14/2017 7:49:56 PM. by vijay. Forum started by guru
2190
Southwest of my house is week..entrance from west side....what to do that the we
Last answer on 10/2/2009 3:52:53 PM. by Priti Arora. Forum started by rajiv jain
2932
Help on Staircase and Elevator design
Last answer on 7/3/2020 10:46:12 PM. by S L Gupta (Civil Engg). Forum started by Dev
4162
help required by experts
Last answer on 12/25/2020 3:37:50 PM. by S L Gupta (Civil Engg). Forum started by gaurav
3216
for a flat
Last answer on 10/13/2010 5:18:56 PM. by lokareddy. Forum started by shrawan
1604
effects of cut of southwest side of a home
Last answer on 10/17/2015 9:10:01 PM. by JAI PRAKASH. Forum started by Pankaj Gupta
2595
Last answer on 2/11/2015 10:53:37 PM. by Nageshwar. Forum started by SAROJINI
2005
lift can touching north wall ?
Last answer on 8/31/2017 12:25:43 AM. by S L Gupta (Civil Engg). Forum started by venkat
2128
about staircase
Last answer on 1/21/2014 5:49:56 PM. by S L Gupta (Civil Engg). Forum started by v suresh
2527
sir, i have a east facing home, which front side two shop and ceter main door an
Last answer on 1/6/2013 6:04:55 PM. by sapnajain. Forum started by sapnajain
3889
2072
STAIRCASE & OVEHEAD WATER TANK
Last answer on 1/2/2013 1:22:50 PM. Forum started by kuldeep
1880
SIR,my house staircase facing in north side and water tank is above starcase in
Last answer on 1/2/2013 7:48:40 PM. by Pavan. Forum started by kuldeep
if house face north side and kitchen face also north side
Last answer on 6/9/2012 11:43:32 AM. by Gunjan Utraja. Forum started by preetam kirpalani
2243
2859
Last answer on 12/9/2010 11:06:35 PM. by S L Gupta (Civil Engg). Forum started by kapil
4480
17
Staircase
Staircase railings
Stairs
Stairs Design
How to Design Stairs?
What are various designs available in side hung doors?
Designs available in Side Hung Doors.....
Brick Arches
