| Preliminary Works during Ground Work Entire area should be cleared of all roots, bushes, vegetation etc. for a smooth construction works. |
| Purchasing Guidelines for Coarse Aggregate Sub standard material reduces the strength of RCC, Reinforced Cement Concrete, by 10 to 30 %. Use these steps to ensur.. |
Pool Pumps Pool pump is the most important equipment of your swimming pool. This device works with filter to maintain the cleanline |
