what are these 3 types
Sun Dec 27, 2015
sushantsah
Topic: what are these 3 types
cement
cement for base course
cement grey
what are diff cement mentioned in estimate ?
do we use same cement for overall construction from foundation to finish
or diff type ?
please suggest
Mon Dec 28, 2015
Cement means cement which is grey for all type of work in the building from foundation to finishing. In flooring we use grey cement and white cement.
Tue Dec 29, 2015
These are types of cement. yes they are available. Please arrange as per your labors requirement.
2685
Last answer on 4/26/2021 10:00:27 AM. by
mohamed
Sanjeev Thakur
4784
I am n interior designing student so i want more information about carpet making
Last answer on 7/3/2020 11:13:00 PM. by
Swati Sharma
Swati.Gosalia
1622
i am asking for staircause ...Run=5feet,Raise=9feet......in this situtation ..wh
Last answer on 4/22/2016 12:12:17 PM. by
Selvan
18383
Last answer on 11/5/2021 3:48:21 AM. by
Quovino
Last answer on 7/6/2021 5:06:36 AM. by
Last answer on 11/10/2016 5:24:28 PM. by
raviprakash
2073
construction of new house on a two side open plot
Last answer on 5/2/2013 1:08:19 PM. by
ashish
ashish
3443
Type of Cement
Last answer on 4/22/2021 5:20:49 AM. by
sumit dua
2406
timer switch for exhaust fan
Last answer on 12/31/2020 2:40:39 AM. Forum started by
Chacha
2071
what type of tape is this and where is it available
Last answer on 12/31/2020 2:33:45 AM. by
Allwyn
2303
i want to see different type of POP on ceiling
Last answer on 12/31/2020 2:33:42 AM. by
jaydeep
radheshyam
2704
plz tell me the cost of making this type of washroom
Last answer on 2/11/2010 2:37:31 PM. by
shikha
2740
Wooden Flooring
Last answer on 2/9/2021 5:39:37 AM. by
Prakash Pandey
atiq khan
2620
which is the cheapest type of flooring
Last answer on 4/4/2010 9:31:51 PM. by
juhi
Ankur
3268
Last answer on 4/19/2010 12:24:10 PM. by
rprao
anjaneyulu
2478
PL. SEND FLAT TYPE INTERIOR INFORMATION WHICH ARE USEFUL FOR MID SEGMENT FLA
Last answer on 5/16/2010 2:04:24 AM. by
amit yadav
shweta
2711
could you send me some more good designs not satisfied with this type of pop cei
Last answer on 6/23/2021 6:18:33 AM. by
Richa Shangvi Interior decorator
maya
1788
from were i can get this type of material
Last answer on 8/28/2010 10:23:44 PM. by
ranjeetsaini
shikhar goel
2270
Which type of flooring is this?
Last answer on 3/29/2011 1:52:13 PM. by
Mohini Sharma
rupali
13969
for kitchen cabinets what type of wood - MDF, HDF, PLYWOOD , is better
Last answer on 7/3/2020 11:24:20 PM. by
ganesan
Types of cupola
Let's find details about types of cupola in this writeup
Styles of dormer
This article contains the list of dormer styles.
Types of arch
Kitchen Cabinets
Aluminum door finishes types
There are variety of options for aluminum door finishes available. Let’s get to know the types and recommendation for..
What are various types of panel doors?
Single panel, Double Panel, Three Panel, Six Panel doors........
Which are various types of vinyl flooring?
Two types of vinyl flooring such as inlaid and printed............
Which types of finishing materials are recommended for glass windows?
1.Glass Former: It is the primary material. 2.Flux: It lowers the melting temperature as well as viscosity. ..
Which are various types of pointing according to designs?
Flush Pointing,Deep Variety ( Weathered and Struck ) Pointing,Raised Pointing
