What is the thickness of PVC pipes and diameter for drainage ?
Wed Jul 28, 2010Total posts : 3
shabbir
shabbir
Topic: What is the thickness of PVC pipes and diameter for drainage ?
1.What should be the max. dia.of rainwater downtake??& why?? 2.What should be the no.& dia. Of R.W.Downtake per for 4000 sft.of a sq.terrace & a geometriclly difficult terrace with many corners & return walls??
The comment above talks about the article   "What is the thickness of PVC pipes and diameter for drainage ?"
Wed Jul 28, 2010Post  #1
Dear shabbir
              In general cases maximum diameter of rain water pipe is 4'' because this dia pipe easly embeded in the 9'' thick wall during masonary. In case official or commercial building when length of building is more and non availabilty of 9'' or 13.5'' wall due to design. than rainwater is drained through duct with the help of 6'' dia pipe. Fix at least 6 nos 4'' dia RWP.
Thu Jul 29, 2010Post  #2
modernplasticsco
modernplasticsco
Post subject: dia of pipe
dia of down take pipe depends up on catchment area of rain water i e amount of water you need to take down through pipe. and no of out lets you want to have on terrace.
Fri Jul 30, 2010Post  #3
Anil Kumar Mishra
Anil Kumar Mishra
Post subject: Rainwater Pipe.
Generally 4" dia pvc pipe with 2-3mm thickness is sufficient for drainage of rain water.However calculations on catcment area,intensity of rain and other variable factors may be considered before construction.
what is the diffrence between u-pvc ans pvc pipes
Last answer on 7/31/2014 7:59:31 PM. by GUNA. Forum started by SANJAY DUSANE
4076
drainage pipe line for toiletfor south facing house
Last answer on 1/19/2022 6:35:06 AM. by S L Gupta (Civil Engg). Forum started by ajitkumar
2943
SIR, I AM CONSRUTING MY HOUSE IN PATIALA AND CONFUSE THAT WHICH PIPE GI , PVC ,U
Last answer on 1/18/2012 8:33:27 AM. by ravi at Dalmia. Forum started by HARISH SAHNI
1826
2100
2230
sewage pipes
9175
2239
Hi i am planning to build a PVC home....Will it be a better idea....
Last answer on 8/18/2012 11:43:32 AM. by S L Gupta (Civil Engg). Forum started by balajee
2386
Sewage and drainage lines
1494
3805
cpvc pipes v,s gi pipes
2738
i need.s windows aluminium with gllas & fire doors pvc construction in india l
Last answer on 2/24/2022 1:02:52 AM. Forum started by muhammad mansoor
2147
are iron doors expensive than pvc doors?
Last answer on 3/2/2014 5:40:13 PM. by Navneet Jharia. Forum started by neelam rathi
2002
Required PVC Wooden Flooring
Last answer on 10/18/2013 3:52:51 PM. by S L Gupta (Civil Engg). Forum started by Krishna Equytech
2047
PVC windows
3752
1793
PVC Walls & Ceilings
Last answer on 12/24/2015 4:20:28 AM. by JAI PRAKASH. Forum started by sushantsah
1989
PLUMBING
2931
Thickness of PVC Pipes and various diameters for drainage are .........
Vinyl
Vinyl Flooring
Sewerage
Sewerage & Plumbing System
Which are various brands of pipes for drainage of soil water?
Brands of pipes for drainage of soil water-C.I. Pipes-CIC..........
Various
