Home -> Forums -> Construction -> Foundation -> what is the thumb rule for piller construction / piller size /steel rod size etc
Sat Jul 21, 2012Total posts : 1
dominate27
dominate27
Topic: what is the thumb rule for piller construction / piller size /steel rod size etc
sir i  am starting building construction  of ground + 3 floors ( 2400 sft), i need to know the following  basic tips/ thumb rule for the foloowing
1)  thumb rule for  footing depth & width
2) thumb rule for  piller size & beam size
3) thumb rule for steel rod usage
4) thumb rule for plinth beam
 i  feel  eliminating 16 mm rod in piller instade using 10mm & 12 mm combination for pillers will give more strength?
can any one clarify me please
Mon Jul 23, 2012Post  #1
       The size/ design of foundation of column i.e. footing size depth can be designed according to the safe bearing capicity of the soil at site , span of column and loading condition of the column.Simillarly the column design, beam design and the steel bars are designed accordingly. So when you are constructing your dream home with an expenditure of many lacs. So my advice is that you should contact any structural engineer of your town/city for design and I am sure that this small amount spent by you will give you saving and strength to your building.
2995
1945
Last answer on 7/3/2020 11:23:38 PM. by JAI PRAKASH. Forum started by rajesh
4127
2154
New 4 storey building design
3180
3884
stone foundation
1458
Dear Sir,We are planing to building faction hall at our place. function hall she
Last answer on 8/8/2017 12:11:18 PM. by S L Gupta (Civil Engg). Forum started by Sha alam
1586
i want to knw cost about making a piller height 4 feet and 8*8
Last answer on 6/9/2021 8:12:51 AM. by ]Greis. Forum started by RUPESH RATHORE
65240
5207
3134
1762
2687
Steel Size
Last answer on 8/21/2014 12:31:17 PM. by S L Gupta (Civil Engg). Forum started by ferous
2610
1878
column
1065
2644
Please suggest piller size and location
Last answer on 2/13/2015 9:56:49 AM. by vijay. Forum started by vijay
2317
Rcc Piller Size
Last answer on 4/21/2014 3:19:05 PM. by S L Gupta (Civil Engg). Forum started by Sayed Taqui
3426
2684
Pillar
2140
Curing urgent
2372
structure work
5166
Pillar foundation
2204
new house
2821
building a house
1992
Construction Agreement
3091
Foundation
2272
Foundation
1477
10048
3660
Foundation
2115
Structure proof checking
2558
Foundation design
2462
2468
Saria and cement
3657
Wall Thickness
2679
3180
13268
Steel Type
Right size cupola
Basic rules while designing the light.
Every activity that takes place in the interior must have lights of the right kind, intensity and the right direction.
What is the recommended size of wooden boards?
Maximum length of the board should be 180 cm.
