How to arrest leakages through expansion joints.
Fri Nov 20, 2009Total posts : 3
Jagadesh Babu
Jagadesh Babu
Topic: How to arrest leakages through expansion joints.
Fri Nov 20, 2009Post  #1
Girish
Girish
Post subject: Type of expansion joints
1)
Swellable polymer / butyl rubber water stop strip that expands in contact with water , to stop water from entering sub structures.
Hydrophyilic Waterstop
2)
Closed Cell polythelene joni filler in rod or sheet form for structural movement joints in concrete , brick and blockwork
3)
Cork bitumen impregnated filler board is an ideal expansion join filler for water retaining structure
applications include sea walls, roads, runways, hard standings, basements, subways and
4)
Two part cold applied pouring grade polysulphide sealant for horizontal joints or gun grade for vertical joints
5)
Elastomeric selant
6)
One part polyurethane sealant for critical joints
Fri Nov 20, 2009Post  #2
Girish
Girish
Post subject: TYPICAL APPLICATION METHOD
Sketch attached for typical application method of polyurethane sealant
for roof waterproofing.
Fri Nov 20, 2009Post  #3
Girish
Girish
i am unable to upload the sketch here with reply
please refer this link
http://www.gharexpert.com/image_Strip/single_Full_Image_for_ALL.aspx?Type=single&ImageId=11879&CatId=18&h=768&w=1024
6621
Last answer on 1/7/2022 1:25:49 AM. by Girish. Forum started by Girish
1973
while building an extension building next to old one the ceilings were kept apar
Last answer on 8/20/2011 2:20:45 AM. Forum started by D.Ramachandran
5696
seal coat on roof
Last answer on 9/19/2010 11:16:18 PM. Forum started by viswanath
roofing on open terrace
3609
Tile flooring verses Marble
Last answer on 7/3/2020 9:54:03 PM. by Deven. Forum started by Love thy community
1804
1142
sir my i have problem in bath room 1st floor bathroom seen in groundfloor ceili
Last answer on 1/31/2017 12:01:05 PM. by S L Gupta (Civil Engg). Forum started by raj
2300
3129
3972
water proofing of water tank
3046
Leak in Sunken Portion
Last answer on 2/16/2021 11:40:50 PM. by leelindsey. Forum started by resident
2612
robosand
Last answer on 1/24/2022 5:28:08 AM. by srinivas reddy. Forum started by srinivas reddy
2774
roof leakage
3985
Roof leakage
2939
2328
477
Good afternoon, I have been experiencing quite a lot of pain in my joints lately
Last answer on 1/31/2022 4:08:40 AM. Forum started by lxst
AuStRalia!!CaNaDa" 91- 8769373431VASHIKARAN sPeCiAlIsT
Last answer on 12/30/2024 1:08:23 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:08:17 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:08:11 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:08:05 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:58 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:52 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:46 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:40 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:34 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:27 AM. Forum started by rupeshji
Muslim-Shakti-Astro 91-8769373431Black Magic Specialist In Dubai,,qatar
Last answer on 12/30/2024 1:06:59 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:47 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:39 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:33 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:27 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:21 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:15 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:09 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:03 AM. Forum started by rupeshji
Boy / Girl 91-8769373431~iNtErCaSt LoVe MaRrIaGe;;LoVe BaCk SpEcIaLiSt
Last answer on 12/30/2024 1:05:50 AM. Forum started by rupeshji
Electric
Preventive
Which are various types of pointing according to designs?
Flush Pointing,Deep Variety ( Weathered and Struck ) Pointing,Raised Pointing
Reasons of dampness
Surface
Centering
Importance
