Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> How to avoid Heat in Top Floor
Mon Apr 28, 2014Total posts : 1
Aarif Eqbal
Aarif Eqbal
Topic: How to avoid Heat in Top Floor
Hi
I shifted recently  at Top Floor of Building .As tempreature  is slowly increasing to 37-38  degree and above .Heat inside flat is unbearable .
What will be the cost .
Area for the Top Area is 928 square feet.
Kindly suggest the cost and the way out .
Tue Apr 29, 2014Post  #1
Dear Aarif
Internal Treatment:
1. You can treat both types of slabs both types of slabs either flat roof or pitched roof.
2. You should provide Air gap for under exposed surface of roof by fixing false ceiling under the roof.
3. Ventilation abutting the roof also helps for passing the heat out of the room.
4. You should install false ceiling with thermal insulating materials.
5. You may paste suitable adhesive and sealers at inside surface of the exposed roof for fixing Light insulating materials. Some insulating materials are glass wool, fiber glass wool, mineral wool, thermocol, rubber foam etc.See the link below for more information
http://www.gharexpert.com/articles/Finishing-1607/Thermal-Insulation-Home_0.aspx
2531
Reasons of dampness
2233
20668
Heat reduction in the top floors
Last answer on 3/15/2011 10:12:45 PM. by Rohan Jaacob. Forum started by Dr. Tiwari
1982
Underfloor Heating - Home Heating Equipments
Last answer on 6/16/2015 4:05:32 AM. by JAI PRAKASH. Forum started by kevinlee
3910
2203
my house is on ist floor,but it gets too much heated due to terrace , what to do
Last answer on 10/2/2009 10:44:20 PM. by Priti Arora. Forum started by salim noorani
2977
Last answer on 12/31/2020 2:26:35 AM. by rajendrakumar. Forum started by mary cecil
1191
I have an area of 1944sq feet in this I want graden and three floors house gron
Last answer on 4/23/2018 11:19:21 PM. by S L Gupta (Civil Engg). Forum started by Dilip Teja .G
1598
2401
what kind of roof heat resistent
Last answer on 2/11/2011 1:28:43 AM. by Nikita. Forum started by arun
1824
Which color tiles good for Heat
Last answer on 1/10/2016 8:51:34 PM. by JAI PRAKASH. Forum started by venkatesh
2321
3368
2419
Last answer on 10/18/2016 5:20:22 PM. Forum started by sandeepkelkar
1967
Over Head Water Tank
3502
3726
new building aircrack
Last answer on 4/3/2013 5:21:21 PM. by akmurty1. Forum started by Arun
2274
Which Floor is better.. Top or Ground
Last answer on 6/15/2012 6:18:16 PM. by amit saini. Forum started by amit saini
1961
inbuilt burner
Last answer on 7/4/2020 2:12:51 AM. by JAI PRAKASH. Forum started by ARVIND GOYAL
5811
3793
9885
2670
4628
4143
2865
5007
3657
1865
2801
2610
2373
2462
2638
1807
3608
6254
Kitchen Counter Tops Part-1
Avoid
Avoid Short Circuit
Avoid daily short circuit and overloading with the use of MCB(miniature circuit breaker), and save your electrical app..
Kitchen design mistakes
Types of cupola
Let's find details about types of cupola in this writeup
Protect
Protect Your Family from Dust
What are various types of glasses used in windows?
Obscure glass provides you privacy allowing abundant light to the room.Tinted glass provides additional shading from d..
Pool heaters
Surface
