Home -> Forums -> Construction -> Safety Tips -> How to avoid crack in the new construction
Sun May 09, 2010Total posts : 4
vrnavukarasu
vrnavukarasu
Topic: How to avoid crack in the new construction
I am construct new building, how is avoid the crack in the building
Mon May 10, 2010Post  #1
Post subject: Reply- How to avoid
Dear vrnavukarasu,
Cracks in building are a common occurrence and these occur due to carelessness of contractor, mason, and ignorance of house owner and using of inferior materials in construction. It is important to understand the causes and the measures to be taken for their prevention. Materials such as bricks, mortar and concrete, which contain considerable quantity of water at the time of construction, dry out subsequently and under go major contraction.
for further details you can read articles available at links below:
http://www.gharexpert.com/home/new_categorylist.aspx?PL=2&CATID=1371
S.L.Gupta
Mon May 10, 2010Post  #2
juhi
juhi
Post subject: yes
hello vrnavukarasu,
You can ignore those but you have take some of the precautions. That are
1.    Minimize the mix water content by maximizing the size and amount of coarse aggregate and by using low-shrinkage aggregate.
2.    Use the lowest amount of mix water required for workability and placement; do not permit overly wet consistencies.
3.    Use calcium chloride admixtures only when necessary.
4.    Provide contraction joints at reasonable intervals, 30 times the wall thickness is a good “rule-of-thumb”.
5.    Prevent rapid loss of surface moisture while the concrete is still plastic through use of spray-applied finishing aids or plastic sheets to avoid plastic-shrinkage cracks (more important in slabs)
6.    Prevent extreme changes in temperature after placement and initial cure.
7.    Properly place and consolidate the concrete.
 and i also agree with s. l. gupta gharexpert have many good articles which can help you..
bye take care..
Thu May 13, 2010Post  #3
N C Pathan
N C Pathan
Cracks generally occur at the junction of brickwork and bottom of beams. This is the source of leakage in future. To avoid this put chicken mesh at the junctions before plastering. To avoid honey combing use proper grade of concrete and control water cement ratio. Ensure during concreting the cement slurry does not come out from the concrete. This can be overcome by putting plastic paper below the reinforcement. Always hire services of a competent civil engineer when the work is in progress. There are a number of other measures that can not be covered in just one or two pages.
Sat May 21, 2011Post  #4
bhattkalpit
bhattkalpit
hi everybody,
for my new home structure is ready and now builder is going to start internal and external plaster and then flooring.
i have seen some macro cracks in some house in my new society, so to avoid the same i am looking for goods tips and proportion of material is required.
thanks & regards,
Kalpit
Safety Tips-Construction Questions (20)
2503
3726
new building aircrack
Last answer on 4/3/2013 5:21:21 PM. by akmurty1. Forum started by Arun
4035
4075
3575
construction current rate
2508
1977
Supervision cost
933
any new methods for quick construction ??
Last answer on 7/3/2020 10:05:55 PM. Forum started by PAVAN K
8421
Roof Beam crack
1409
crack on wall plaster by gypsum
Last answer on 11/22/2016 1:25:44 PM. by S L Gupta (Civil Engg). Forum started by Rizwan
1522
How will the large amount of new construction
Last answer on 9/9/2016 11:16:25 PM. by bhuvaneshwaran bn. Forum started by Satvinder kaur
1670
1181
2322
depth of footing
Last answer on 1/13/2014 2:32:16 PM. by S L Gupta (Civil Engg). Forum started by Rohit Patel
2668
Estimate require for new construction
Last answer on 7/3/2020 10:05:34 PM. by JAI PRAKASH. Forum started by Pradeep Patil
2208
Need cost for New construction - 900 SFT
Last answer on 3/4/2015 8:32:16 PM. by JAI PRAKASH. Forum started by Marimuthu
4264
860sqft construction
Last answer on 10/12/2015 6:35:12 PM. by Rahul. Forum started by Shivaprasad
i want a good vastu plan for my new construction.south facing.30x40.
Last answer on 10/21/2010 8:47:24 PM. by sabina vanjani. Forum started by ganapathy
3157
I m starting my new business of construction , kindly help me with some details
Last answer on 7/24/2021 4:15:31 AM. by Rinder76. Forum started by Tarun
1846
SLAB LOADING
Last answer on 12/24/2015 4:05:10 AM. by JAI PRAKASH. Forum started by ANISH
How To Repair Cracks
Happy
Happy New Year 2009
Surface
Avoid
Avoid Short Circuit
Avoid daily short circuit and overloading with the use of MCB(miniature circuit breaker), and save your electrical app..
Protect
Protect Your Family from Dust
