Sun Sep 08, 2013Total posts : 4
laxminarayana.s
laxminarayana.s
Topic: how to calculate 1 sq foot rcc,brick work and plastering rate
Sun Sep 08, 2013Post  #1
Rudra Nevatia
Rudra Nevatia
You can perform rate analysis using
http://tufhat.com/procure
Mon Sep 09, 2013Post  #2
Dear Laxmi
          Your query is not clear. However RCC is measured as length x breadth x thickness = cubic feet , Brick work is as length x height x thickness of wall = cubic feet and plaster is as length x width = square feet.For Rates use Estimator link below.
http://www.gharexpert.com/Estimator/Startpage.aspx
Tue Sep 17, 2013Post  #3
pramod
pramod
Dear Sir , rates can be calculated as under.
RCC ( 1:2:4) per 35 cubic . :
cement 6.40 bags + sand 13 bag + aggregates 26 bags
Brick work  per 35 cubic feet :
cement 1.20 bag + 31 bag sand
Plastering per 10 square feet :
cement 0.86 bags + 5.50 bags
now for each calculated rates add 30 % labor cost + 3 % contangencies. you will get appox. rates.
with regards pramod rawat
B. Tech . (civil)
Tue Sep 17, 2013Post  #4
Good reply from you Pramod
labour charges rates
3651
3925
2521
construction const
4232
labour rate
2781
Plaster work
2421
5207
2632
Dear sir,I need information for RCC Brick work estimate for 2400 sq ft plint
Last answer on 7/4/2020 12:05:21 AM. by S L Gupta (Civil Engg). Forum started by nilesh
191901
2515
Cement
3669
wals
3411
HOW TO CALCULATE BRICK IN A 200 SQF WALL WITH HIGHT IS 10 FEET AND WIDTH IS 9"
Last answer on 8/21/2011 3:35:21 PM. by S L Gupta (Civil Engg). Forum started by sohail
11587
RCC + Brick work estimate for 2400 sq ft construction- Update
Last answer on 5/7/2014 4:12:37 PM. Forum started by nilesh
1912
foundation type confusion : pls suggest
Last answer on 12/18/2015 11:22:33 AM. by S L Gupta (Civil Engg). Forum started by sushantsah
21329
how much cement is required for 100 sq wall for plastering and brick work.
Last answer on 3/14/2013 2:12:10 PM. by S L Gupta (Civil Engg). Forum started by paresh
2303
how to calculate brick estimation
Last answer on 1/22/2022 7:01:42 AM. by bhuvaneshwaran bn. Forum started by mohammed nayeemuddin
3262
compound wall
17
What is acre
