Thu Jan 05, 2017 | Total posts : 3 |
| Topic: How to calculate Built Up Area to Carpet Area
Subject: How to calculate Built Up Area to Carpet Area for the Calculation of the Cost of Construction.
Place: Nasik (Maharashtra)
Dear Sirs,
Here in a place Nasik in Maharashtra, when we buy the Constructed Home, may it be an Apartment, Row House, Twin Bunglow Or an Independent Bunglow, the builder quotes the price per square feet depending on the location of the city, for example @ Rs.4,000 per square feet. The calculation of the total Built Up area is done at the discretion of the Builder (Seller) of the House. They normally first calculate the Actual Carpet Area of the Apartment, for example 2BHK carpet area 800 square feet. In this carpet area, they add 25% to make it Built Up & then calculate 1,000 square feet x Rs.4,000 per square feet. Some, builders add 30%, 33%, 35%, 40% or even a whopping 45% over the carpet area & call it SUPER BUILT UP SALABLE AREA.
In such situation, how to calculate the construction costs of an Apartment Or a Bunglow, when we consturct it on our own? The 800 square feet carpet area apartment is sold as 1,000 sq. feet (25%), 1,040 sq. feet (30%), 1,064 sq. feet (33%), 1,080 sq. feet (35%), 1,120 sq. feet (40%) or even 1,160 sq. feet (45%) Salable Area.
The normal construction costs of an apartment or bunglow is estimated at Rs.1,200 to Rs. 1,400 per square feet all over India depending on the location. How shall we calculate these construction costs of Rs.1,200 per square feet, On carpet area or built up area? If, on built up area, at what percentage?
Please advice.
Many thanks in advance. |
Fri Jan 06, 2017 | Post #1 | S L Gupta (Civil Engg)
Join date: Mar 2008 | Dear Anil Shah, The construction cost is calculated on the built up area. Carpet Area is the area enclosedwithin the walls, actual area to lay the carpet. This area does not include the thickness of the walls. It is the actual used area of an apartment.
Built up Area is the carpet area plus the thickness of walls and the balcony.
Super Built Up Area is the built up area plus proportionate area of common areas such as the lobby, lifts shaft, stairs, etc. Sometimes it may also include the common areas such, swimming pool, garden, clubhouse, etc.
Generally CARPET AREA is around (70 to 80)% of SUPER BUILT UP AREA. But note that this percentage varies from project to project and builder to builder.
Fri Jan 06, 2017 | Post #2 | ANIL SHAH
Thanks very much indeed for your detailed explanation.
I may now conclude that the Average Construction Cost for the Home in India for the Built Up Area is Rs. 1,200 per Square Feet & for the Carpet Area is Rs. 1,500 per Square Feet with 25% normal loading..
Warm Regards.
ANIL SHAH. Mobile: 9923456635. | |
Tue Jan 10, 2017 | Post #3 | S L Gupta (Civil Engg)
construction if we spent some time about design, specification and
quality of construction than there is lot of improvement one can find in
construction. gharexpert.com website provide maximum engineering detail relating to construction if one have time and read these. Visit again for any problem relating to construction. | |
Articles that might interest you! | | Rugs for Living Room Give modern and contemporary look to your living room with wide range of area rugs and carpets. Living room rugs are p.. | | Carpet Cleaning Tips It is a good idea to clean dirty carpets thoroughly for their long life.
Proper cleaning not only maintains the pret.. | | Selection of A Site The selection of a site depends upon ones present and future spatial requirements, the envisaged available funds, one’.. | | Utilization of Space Under Stairs It seems that most people forget to decorate the space under stairs. Though the space is small yet it’s easy to create.. | | What are various termite control methods? INITIAL INSPECTION AND REPORT requires a complete thorough inspection of the buildings and surrounds, and a detailed w.. | | What is recommended size and shape of building for the protection in earthquake prone areas? All parts of a building should firmly be tied together and stiffly braced at corners in such a manner that the whole s.. | | What are requirements of drainage and sanitation for dwelling area covered with individual? Requirements of drainage and sanitation for dwelling area covered with individual- One bathroom provided with a tap..... | | Which are various methods for the protection of dampness in buildings? REPLASTERING: The most common method is to scale the affected damp plaster back to the brickwork and replaster the aff.. | | Types of lighting according to the intensity of light used. There are three basic types of lighting according to the intensity of light used: | | Outdoor Rugs Outdoor rugs grab attention and are aesthetically appealing. These rugs are usually used for door mats, swimming pool,.. | | What are various types of glasses used in doors? Types of glasses used in doors-Clear window glass, Plate glass, Prism glass, Quartz glass, Processed glass....... | | What are advantages and disadvantages of folding doors? Advantages of folding doors- Easy to install,washable, durable, superior sound damping. Disadvantages-sensitive to har.. | | What are various designs available in wooden doors? Designs available in Wooden doors..... | | What is standard size of internal folding doors? Size, Thickness and Weight of Internal Folding Doors....... | | What affects the life of doors? What can we do to increase the life of the Wooden doors? Tips to increase the life of Wooden doors.... | | What is the standard size of frame for Plastic/PVC doors? Plastic Door frame size carrying one or two shutters...... | | What are various frames recommended for Plastic/PVC doors? Frames for Plastic Doors.......... | | Which place is appropriate for sliding door? Appropriate places for sliding doors-Bathrooms, Backyards, Commercial structures........... | | What are various frames recommended for glass doors? Frames for Glass Doors-Wooden frames, Steel frames, Aluminium frames...... | | Which place is appropriate for folding doors? Appropriate places for folding doors-Homes, Offices, Guest rooms, gives attaractive and stylish look........ | | What are the various accessories recommended for folding doors? Accessories for folding doors- Door Handles, Door Fasteners,Door Viewers....... | | What affects the life of doors? What can we do to increase the life of the Plastic/PVC doors? Tips to increase the life of Plastic doors.... |
