Home -> Forums -> Construction -> Start Construction -> how to colour/dye/stain concrete?
Tue Feb 05, 2013Total posts : 2
aammiitt
aammiitt
Topic: how to colour/dye/stain concrete?
how to colour/dye/stain concrete? what is the easy process....kindly giude...
Mon Feb 11, 2013Post  #1
akmurty1
akmurty1
Post subject: how to colour/dye/stain concrete?
by applying red/green/black oxide flooring over the surface while it is wet
Tue Feb 12, 2013Post  #2
Dear Aammiitt
              After laying cement concrete in floor then at time of finishing the surface with neat cement shullary, mixed the cement color generally red or green in the cement for shullary. The color mix cement shullary then applied on the already laid cement concrete. It is a simultaneously process when concerte is wet.
2993
staining concrete or similar easier effects
Last answer on 11/19/2012 3:24:54 PM. by S L Gupta (Civil Engg). Forum started by aammiitt
1997
Yellow patches coming in granite
Last answer on 2/25/2022 1:47:02 AM. by S L Gupta (Civil Engg). Forum started by sam_m400
1849
Roof Painting
1514
concrete floors
1389
Colored concrete floor
Last answer on 10/22/2016 11:14:47 AM. by S L Gupta (Civil Engg). Forum started by Pooja
2843
Last answer on 9/19/2012 6:08:49 PM. by tjackson. Forum started by Sujatha Kumar
2622
hard water stains on shower panel glass
Last answer on 2/11/2022 12:59:20 PM. by Nikita. Forum started by madhu
3827
1748
1446
3463
Cost of concrete walls
25204
Best Color Combination for Modular kitchen Cabinets and walls
Last answer on 7/4/2020 3:51:00 AM. by basil. Forum started by raghuam
3490
Paint selection
Last answer on 7/3/2020 10:41:47 PM. by Messi1999. Forum started by anwar
2624
paiting
Last answer on 7/3/2020 11:21:56 PM. by Gunjan Utraja. Forum started by Abraham
2180
What is the best colour for the inside walls if I want to retain the colour of t
Last answer on 10/26/2010 3:45:23 PM. by nevile. Forum started by Evas T. Bwoye
3332
Study Room Vastu
Last answer on 1/29/2021 7:27:25 AM. by dorishall. Forum started by Avinash Ojha
1925
hallocan all doors chokhat [fraim] be of red colours ororall doors of a home can
Last answer on 4/6/2015 12:15:50 PM. by S L Gupta (Civil Engg). Forum started by archna
1897
i want to color my garment showroom my dob is 08/02/1976.present color whitemy n
Last answer on 2/16/2013 4:50:38 PM. by tianclaian. Forum started by arabinda ghosh
2211
zero slump concrete
2451
3274
3285
4429
3975
2199
2702
4212
5170
2379
2295
1997
2449
2115
3195
2048
12516
2164
2727
Decorate
Carpet
Carpet Cleaning Tips
Concrete Decor
Concrete Mix Ratio
Ready
Ready Mix Concrete
