Interior
how to do gas piping for a residential ground floor independent building should
Mon Dec 26, 2011
elizabeth
Topic: how to do gas piping for a residential ground floor independent building should
how to do gas piping for a residential ground floor independent building should it be under ground or on the wall
The comment above talks about the image below.
Click on
the image to enlarge.
Tue Dec 27, 2011
Dear Elizabeth
In my view, the gas pipe should be on the wall.
Kitchen-Interior Questions (39)
2572
Last answer on 4/12/2017 12:52:16 PM. by
Vandana Joshil
5086
Last answer on 3/25/2016 1:08:35 AM. by
Tanish
raviprakash
1315
i want to build up commercial cum residential biliding in which ground floor sho
Last answer on 12/14/2015 12:01:37 PM. by
ramkrishan86
1481
Last answer on 12/17/2015 2:52:33 PM. by
omprakash
2649
Independent second floor in a ground & first floor duplex
Last answer on 2/12/2011 1:58:51 PM. by
Mohini Sharma
Archit Jain
5029
pls sent a suitable front elevation for 20x60 ground and first floor building
Last answer on 1/22/2022 12:11:35 AM. by
bablu suthar
naga
3642
I want to built a house with stilt,ground floor
Last answer on 8/30/2021 6:11:55 AM. by
venkatesha
1274
HAI, MY BUILDING GROUND FLOOR HEIGHT 11.25FTS
Last answer on 7/4/2020 4:24:16 AM. by
VASUDEVA KUMAR
2125
Want to build 30*35 residential building suggest me some plans
Last answer on 1/5/2022 12:37:08 AM. by
sweety
ihsan
2720
Last answer on 1/4/2022 11:15:30 PM. by
Ahmed
qader
2101
Last answer on 1/27/2015 7:24:32 PM. by
R. Ramachandran
Last answer on 6/9/2015 4:30:39 PM. Forum started by
Debi Prasad Nayak
2557
Bye Law
Last answer on 1/5/2022 12:39:33 AM. by
how to line out work to residential building
Last answer on 7/4/2020 2:18:55 AM. by
patil kiran
1702
Last answer on 1/2/2021 5:22:40 AM. by
MEDOJU YADAGIRI
1598
How much Marole required
Last answer on 7/3/2020 11:26:58 PM. by
Yousuf
Related to Sunken Slab
Last answer on 10/25/2015 8:30:24 PM. by
SOUNAK SAMANTA
2388
chrome
2446
Last answer on 8/6/2011 2:32:51 PM. by
nita
2858
modular kitchen
Last answer on 2/23/2022 4:38:18 PM. by
Anu
2799
Modular kitchen in chennai
Last answer on 2/19/2022 2:12:28 AM. by
Sally
brandoo
3457
Last answer on 2/4/2022 11:19:50 PM. by
Vaasku
jayakrishnan
2911
Last answer on 1/21/2022 6:49:43 PM. by
Suveera
6818
Kitchen Ventilation
Last answer on 1/19/2022 2:55:03 AM. by
sugantha
sukamalroy
3428
Kitchen Island
Last answer on 1/5/2022 2:57:02 AM. by
Mike Stanley
tiwari_p_k
2841
Last answer on 1/5/2022 12:58:49 AM. by
Misato Katsuragi
Padmanaban
7310
Modular Kitchen
Last answer on 11/30/2021 12:56:09 AM. by
axelbach
Veena Gil
2927
Kitchen Sink
Last answer on 11/30/2021 12:21:26 AM. by
Anjleen
Sasikala R
2490
Introduction
Last answer on 10/23/2021 8:23:11 AM. by
davidraju
3661
Small Space Kitchen
Last answer on 9/15/2021 5:01:17 AM. by
KVSN RAJU
Shital Miriyala
2662
Thank you for all you do
Last answer on 7/19/2021 5:14:13 AM. by
raghav
2872
Kitchen Design Ideas
Last answer on 5/18/2021 7:44:04 PM. by
rafi
b.arunaseshan
2550
'island' counter in kitchen
Last answer on 1/2/2021 5:27:46 AM. by
Shashi Panwar
Kitchen Door
Last answer on 1/2/2021 5:22:53 AM. by
K. Basu
2540
Last answer on 1/2/2021 5:22:28 AM. Forum started by
batambuze abdu
3348
Last answer on 12/31/2020 2:45:52 AM. by
juhi
ruchika jain
2626
How much would be the approximate cost of setting up a kitchen like this?
Last answer on 12/31/2020 2:40:21 AM. by
ranjeetsaini
debashish
3952
Last answer on 10/11/2020 7:21:30 AM. by
maruthi prasad
3285
Kitchen modular size 8*8 fit
Last answer on 10/11/2020 7:13:57 AM. by
Hitendra singh bhadoria
Orientation of Building
Pool Heaters
You spend a lot of money to construct a swimming pool and on its other equipments. But if your pool is frequently too ..
Sewerage & Plumbing System
Pool Pumps
