Steel
Mon Oct 26, 2009
Shabbir Manzoor
Topic: How to ensure weight of steel members?
How much of binding wire is required per ton of main reinforecement? With regards,
The comment above talks about the article
"How to ensure weight of steel members?"
Tue Oct 27, 2009
Prem Bhatia
Post subject: Quantity of binding wire
The quantity of binding wire depends on the diameter of MS steel bars used in RCC. For example if you use 12 mm MS steel bars instead of 10 mm steel bars then weight of steel is 1.5 times but consumption of binding wire remains same. Similarly MS steel bar of 12mm to 25mm is used in the beams but the quantity of binding wire remains approximately same. Binding wire required for binding steel bars is approximately 2kg to 4kg per metric ton.
3059
steel formula
Last answer on 4/16/2014 8:05:15 PM. by
shaik khaja nayab rasool
2287
HI WHAT IS THE WEIGHT OF 1MX1M BARBEDWIRE FOR @10GAUGE
Last answer on 12/31/2020 2:08:42 AM. by
H S Rathi
K.SRINIVASAN
2647
Which is better for losing weight: peanuts or mahana?
Last answer on 9/24/2021 1:34:49 PM. Forum started by
Celly Swehykol
664
What do you think about the effectiveness of diets for rapid weight loss?
Last answer on 6/14/2021 9:43:38 AM. by
Salammm
Salammm
419
Members, where are you looking for new skincare options?
Last answer on 11/8/2021 2:03:47 AM. by
Cermit
RadyGoldy
1726
what is the cost and feasibility of installing a water softner for 4 members
Last answer on 10/16/2014 12:52:21 AM. by
neelam rathi
2899
RCC Roof
Last answer on 7/4/2020 12:19:59 AM. by
ARVIND GOYAL
4331
Last answer on 3/15/2011 6:15:21 PM. by
Mohini Sharma
kanwer sajjad
2217
Last answer on 4/21/2015 11:35:52 AM. by
Last answer on 7/26/2021 2:26:58 AM. by
which material is to be used for balcony railings iron or steel and why? i hope
Last answer on 4/21/2015 10:34:31 AM. by
Last answer on 5/3/2016 12:53:30 AM. by
K M Sendhil
9216
Standard weight of iron grill per feet
Last answer on 8/25/2014 8:17:34 PM. by
srinu
4035
what is the weight of MSA 45x45x6 angle per meter?
Last answer on 12/31/2020 2:08:28 AM. by
Priti Arora
K.SRINIVASAN
4940
COLUMN AND STEEL DESIGN
Last answer on 1/9/2021 12:01:44 AM. by
Kaleemullah
4940
Kaleemullah
2312
i want to know that how u fixed this lights behind the woodern member pls let me
Last answer on 12/31/2020 2:26:38 AM. by
monu
rimpy
1608
I have north east missining in my flat.What adverse effect it has on me and othe
Last answer on 3/30/2010 1:35:32 PM. by
Ajit Tareeka
Raman Mediratta
2685
steel requirment
Last answer on 2/1/2022 2:47:12 AM. by
skziro
vijaygutti
15583
Residential complex
Last answer on 6/30/2021 4:27:52 AM. by
lali
4370
RCC Columns
Last answer on 4/14/2021 6:24:55 PM. by
Ahmed
Ahmed
7480
Bar Bending Schedule Software
Last answer on 12/13/2020 8:18:39 PM. by
kongrollo
Prasenjit Roy
2523
steel
Last answer on 7/3/2020 10:06:06 PM. by
saravana prabu
29942
Last answer on 9/26/2018 12:16:44 AM. by
Balaguru
2613
Last answer on 7/23/2018 11:36:52 PM. by
AMIT KUMAR VERMA
9363
Last answer on 5/21/2018 11:53:16 PM. by
George Kattapuram
2262
Current iron rod price
Last answer on 4/23/2018 11:26:02 PM. by
lio
2606
Last answer on 1/27/2017 1:11:45 PM. by
1885
Steel Erectors
Last answer on 8/22/2016 11:36:29 AM. by
MarianneRolfe
MarianneRolfe
Last answer on 4/18/2016 11:23:43 PM. Forum started by
Kaleemullah
Kaleemullah
2382
Last answer on 1/11/2016 2:34:47 PM. by
DURJOU KUMAR MONDAL
DURJOU KUMAR MONDAL
3268
Last answer on 1/11/2016 12:39:36 PM. by
DURJOU KUMAR MONDAL
13772
overlap length to steel
Last answer on 6/16/2015 4:11:51 AM. by
2161
Last answer on 12/26/2014 1:19:11 PM. by
pramod Kumar patel
2539
Last answer on 10/12/2014 9:10:09 PM. by
Rohit Patel
Density of Coarse Aggregate
Steel Roofing
