Tue Jan 19, 2010Total posts : 1
aqeel
aqeel
Topic: How to get more strength with same quantity of cement?
i want to know how to get the size of columns and beams in a newly construction of house or apartment
The comment above talks about the article   "How to get more strength with same quantity of cement?"
Tue Jan 19, 2010Post  #1
Post subject: Get more strength with same quantity of cement
Dear Aqueel
The size of columns are designed on the bases of load bear by the column i.e. the columns size are depend on the load coming on them both dead load and live load. According to loading condition Miled Steel bars to be used in column are calculated. The size of beams are also calculated on the bases of dead load and live load coming on them, the span of beam i.e. length of the beam is also taken at the time of deciding the size of beam.
S L Gupta
2123
I have read your articles regarding the strength of fresh cement,and how cement
Last answer on 9/13/2012 5:19:43 PM. by S L Gupta (Civil Engg). Forum started by George Kattapuram
3591
2671
shuttering calucation
Last answer on 4/8/2014 1:21:34 PM. by S L Gupta (Civil Engg). Forum started by shaik khaja nayab rasool
2997
2395
Last answer on 6/24/2013 9:59:46 PM. Forum started by chethan
3275
20123
12997
HOW TO CALCULATE THE REQUIRED QUANTITY OF BRICKS, CEMENT AND STEEL
Last answer on 7/31/2011 12:54:31 PM. by S L Gupta (Civil Engg). Forum started by sanjay
5176
RCC Lintel , cast and material esitmate
Last answer on 7/3/2020 10:47:13 PM. by S L Gupta (Civil Engg). Forum started by ndmalam
2595
What are the size available What about strength of main door price details
Last answer on 11/18/2013 3:35:39 PM. by S L Gupta (Civil Engg). Forum started by padma
3442
Type of Cement
2465
3791
2037
Estimate
3075
RCC roof
2351
software
Last answer on 12/1/2021 6:05:00 PM. by S L Gupta (Civil Engg). Forum started by chethan
3258
4179
What are the normal fees for architect, civil engineering drawing, quantity surv
Last answer on 5/27/2013 11:48:46 AM. by Vaibhav Jain. Forum started by Anil Sood
HSD
Types of Cement
Concrete Mix Ratio
Buying
Buying tips for Cement
