Home -> Forums -> Construction -> Layout and House Plans -> to help layout plan for 33ft. by 39 ft.
Tue Nov 12, 2013Total posts : 1
firoz raza
firoz raza
Topic: to help layout plan for 33ft. by 39 ft.
hello
i have a plot for 33 by 39 to construction can u give me a layout plan for my plot
Tue Nov 12, 2013Post  #1
Dear Mr.Raza
2408
i want to house plan for 1 floor size 17 feet width and 39 feet lenth
Last answer on 5/29/2017 5:57:46 PM. by Saurav anand. Forum started by rajusapra
2054
Plot size 28*39 south facing plan
Last answer on 9/21/2017 11:59:01 PM. by S L Gupta (Civil Engg). Forum started by kamaljeet
1924
CONSTRUCTION DESIGN
Last answer on 3/8/2017 2:40:59 AM. by S L Gupta (Civil Engg). Forum started by MANISHA
1707
Sir my site east 28feets , west 39 feet's, south 51 feets, north 52 feets please
Last answer on 5/30/2017 11:07:39 AM. by S L Gupta (Civil Engg). Forum started by sudarsanraju
1525
how i will design 18 feet south faced home plan whose length is 39 feet east to
Last answer on 4/22/2018 10:42:36 PM. by S L Gupta (Civil Engg). Forum started by mrigank
2151
house plan for 39 feet road side and 32 feet depth for noth facing
Last answer on 1/2/2015 11:13:55 AM. by seema tyagi. Forum started by ravi kiran
2387
Last answer on 11/21/2013 10:05:53 AM. by S L Gupta (Civil Engg). Forum started by RAGUVINDER SINGH
2380
house layout plan
Last answer on 7/3/2020 11:09:42 PM. by S L Gupta (Civil Engg). Forum started by Deepak
1814
house layout plan
Last answer on 11/3/2015 11:46:11 PM. by JAI PRAKASH. Forum started by Deepak
1791
Need a house layout plan for 450 sq feet land - size - 15ft X 30ft. pls help
Last answer on 10/20/2016 1:50:26 PM. by Beenu Phogat. Forum started by Aditya
4831
Last answer on 5/13/2016 1:11:58 PM. by kushagra khare. Forum started by ankur gupta
1419
Last answer on 9/28/2018 11:39:45 PM. by S L Gupta (Civil Engg). Forum started by Anand jaiswal
1408
East Side 43 fit or west side road view 39 fit or south
Last answer on 2/28/2017 2:57:47 PM. by S L Gupta (Civil Engg). Forum started by Prashant Kumar
857
Last answer on 1/27/2022 6:31:12 PM. Forum started by Rahul T Pal
1967
plot size 31 ft X 78 ft. facing south.please provide best possible layouts
Last answer on 5/18/2015 11:50:41 AM. by seema tyagi. Forum started by ravi shanker
3110
estimation
Last answer on 7/3/2020 10:38:18 PM. by jayaraaj. Forum started by j.maheswari
2241
i want a house plan 33*33 sq. ft west facing. pls help me thnak you
Last answer on 8/8/2017 12:04:30 PM. by Saurav anand. Forum started by yogesh
2464
My home is T type fernt size Is 10.75 *30 after 30 fit size is 39*53 pl advoise
Last answer on 3/16/2011 2:32:10 PM. by Mohini Sharma. Forum started by pukhraj tater
1663
i want to construct house 32 / 39 ....which will be best designs.
Last answer on 10/21/2015 11:20:23 AM. by Beenu Phogat. Forum started by nayeem ahmad
2689
2923
2188
2184
2790
4519
1890
2283
2264
2765
3464
2356
1965
2240
3594
2323
2090
2792
1548
2114
What is acre
