Home -> Forums -> Construction -> Drainage , Sanitary System and Plumbing -> How to hire a plumber
Sat May 28, 2011Total posts : 1
anand
anand
Topic: How to hire a plumber
I have 2 questions: 1. What is the standard sizes of domestic water pipes running into kitchen, bath rooms etc. 2. Where can i get quality affordable fibre bathroom ready made with shower fitted in Hyderabad.
The comment above talks about the article   "How to hire a plumber"
Sat May 28, 2011Post  #1
Dear Anand
            The size of water supply pipe in the kitchen and bath room is 15mm internal diameter of GI OR P V C pipe and this is best suited pipe.
For quality affordable fibre bathroom you should contact show room of your city as at this time our website is not dealing this item. If you need upvc window, door fittings then search on gharexpert.com and we will help you for these items.
3480
Last answer on 1/5/2022 8:16:45 PM. by Gopi Chandra. Forum started by Gopi Chandra
1896
i want to construct a house.is it better to construct it on lump sum turnkey bas
Last answer on 9/2/2015 6:23:03 PM. by Purvi Panchal. Forum started by MELA RAM SAINI
2005
2607
Last answer on 4/5/2012 6:36:29 PM. by Gunjan Utraja. Forum started by Jajati Pattanayak
3191
1544
SIR I AM LEADING TO MY PLUMBER WORK MY PLUMBER WANTS ME TO HAVE CPVC FITTING WHI
Last answer on 4/3/2013 12:21:52 PM. by S L Gupta (Civil Engg). Forum started by sanjay kumar makhija
One place where i can get Architect, Contractor , Plumber, etc for New Home Construction
Last answer on 10/4/2011 3:02:53 AM. by sunny420. Forum started by sunny420
2962
Last answer on 12/31/2020 2:26:35 AM. by rajendrakumar. Forum started by mary cecil
1816
How to hire a carpenter?
Last answer on 2/25/2014 10:22:12 AM. by SLC. Forum started by SLC
2491
Last answer on 1/12/2013 3:08:00 PM. by PCR.Manohar. Forum started by H P GUPTA
1668
Hire a Gharexpert Engineer for Construction
Last answer on 11/17/2014 6:12:03 PM. by JAI PRAKASH. Forum started by RAMESH DUDA
997
I want to hire services for estimating material quantities during various stages
Last answer on 9/26/2018 12:22:00 AM. by S L Gupta (Civil Engg). Forum started by Vinay
1170
Hi, Is there any cost effective methods to hire bending machines for reinforceme
Last answer on 7/4/2020 4:22:17 AM. by S L Gupta (Civil Engg). Forum started by Betty Varghese
2895
Last answer on 4/11/2017 11:10:57 AM. by S L Gupta (Civil Engg). Forum started by vinu
2089
2319
Related to Sunken Slab
2627
Installation of a normal bathtub
Last answer on 9/9/2012 11:00:41 PM. by PR Jawahar. Forum started by raghuam
2551
1777
Energy Saving Tips
Last answer on 9/7/2011 6:07:45 PM. by YaelY. Forum started by shimbhu dayal
1875
tap Connection
3596
sunken slab
3475
1661
2305
3850
flush toilet
1947
4698
Cost estimation for sump tank
2208
water supply
2030
Underground Water storage
2215
sewage pipes
2239
commode & flush type
1937
WC issue
5601
Over-Head water Tank
Vastu for septic tank
2469
Septic Tank Design
3362
3738
position of septic tank
To find a skilled plumber you have to do enough searches for it. Contact friends and relatives for a skilled plumber a..
How to Hire an Electrician
Do you know what you should know before hiring an electrician? You are responsible for all electrical faults and its r..
Superb craftsmanship on wood articles plays a dominant role in making your home wow. A professional carpenter is requi..
Why
