Home -> Forums -> Interior -> Bathroom Flooring -> How to indentify quality of tiles
Thu Mar 26, 2015Total posts : 3
richlyn
richlyn
Topic: How to indentify quality of tiles
Hello,
I have gone to many shops and found the cost ranges for different sizes of tiles.
The per Sq feet ranges vary largely.
However i am confused as to the huge difference in the range.
For eg, one shop quotes a cost of Rs 40 compared to Rs 70 per Sq Ft for a 32x32 double charge flooring tile.
I am not sure about the quality. How can a layman check the quality and what is that  should look for?
please guide me.
Thu Mar 26, 2015Post  #1
        Please follow the steps given below:-
1. Purchase tile from approved or reputed brand.
       2. Verify the rates of tiles according to their brand  from three to four shops.
       3. Judge the quality of material and their rates in case you want to purchase local brand  tiles.
please see the link given below:-
http://www.gharexpert.com/articles/Glazed-Tiles-1498/Purchasing-Guidelines-Glazed-Tiles_0.aspx
Fri Mar 27, 2015Post  #2
himanshu
himanshu
1. You can check for the grade of the tile. Tiles are graded using a numerical numbering system based on their thickness and quality. A rating of 1 is the highest quality and thickest tile available, 3/4-inch thick, and you can use them anywhere. Grade 2 reflects that some imperfections exist but the tile still is usable on walls or floors. These tiles are approximately 1/2-inch thick. Grade 3 tiles are the thinnest, 1/4-inch thick, and are appropriate for use only on walls. Grades 1 through 3 sometimes are referred to as standard, secondary or cull grade, respectively.
2. Secondly you can check for PEI rating. Tiles rated I or II are not suited for installation on a floor. Floor tiles must be rated at III or higher for residential use; the highest rating, IV, is recommended for high-traffic commercial floors. The PEI rating applies only to glazed tiles.
3.Water Absorption (W.A.) A tile’s rate of water absorption: weight of water absorbed as percentage of tile weight. Icon: Umbrella shielding rain Nonvitreous: High absorption (more than 7% water absorbed). Not suitable for outdoor use or for rooms with a lot of moisture, such as bathrooms. Semivitreous: Moderate absorption (3% - 7% water absorbed). Not suitable for outdoor use or for wet rooms, such as bathrooms. Vitreous: Low absorption (0.5% - 3% water absorbed). Suitable for outdoor use and for wet rooms, such as bathrooms. Impervious: Lowest absorption (less than 0.5% water absorbed). Suitable for all interior and exterior uses. Notes: • Glazed tiles are resistant to water at the tile surface, but susceptible at the edges. • All grouts, except epoxies, will allow some moisture absorption. • Only vitreous and impervious tiles should be used outdoors or in bathrooms. • Most glazed tile is fired to give an absorption rate of less than or equal to 3%, which places them in a frost-proof category (vitreous and impervious). • Glazed white body (talc clay) wall tiles are nonvitreous with more than 7% absorption. If these tiles become saturated and are installed in an exterior freeze environment, the tiles will be damaged by the freeze-thaw cycle, resulting in cracked tile or spalling (chipping or crumbling) of the glaze finish. In general, the more resistant a tile is to water, the more it will cost. Impervious and vitreous tiles tend to be more expensive than semivitreous and nonvitreous tiles.
4. Lastly you can also check for the coefficient of friction. Recommended C.O.F. greater than .50 – Recommended for standard residential application C.O.F. greater than .60 – Required for commercial applications to meet or exceed ADA (Americans with Disabilities Act) guidelines
Sat Mar 28, 2015Post  #3
The simplest way is to expose the tiles to the light and check the quality of polish on it. The surface has to be smooth as much as zero errors.
The tiles should be of no.1 grade i.e not bend from corners.
Bathroom Flooring-Interior Questions (29)
2216
Tiles or Marble for Flooring
2569
3077
5325
Last answer on 10/8/2015 1:01:18 AM. by JAI PRAKASH. Forum started by nancy
3544
Which are various types of marble for flooring ?
Last answer on 9/8/2013 12:22:30 AM. by Sri. Forum started by shain thomas
2945
Last answer on 6/25/2009 5:16:44 PM. by rose. Forum started by dinesh
3166
2012
coarse aggregate
2441
639
Which companies can provide high-quality translation of medical documents?
Last answer on 6/30/2021 2:39:08 AM. Forum started by terimad
1752
Terrace
Last answer on 8/5/2013 1:06:35 PM. by S L Gupta (Civil Engg). Forum started by Purvi Panchal
2850
3226
mosaic or tiles
Last answer on 3/19/2013 5:06:52 PM. by Jemimmarichardson. Forum started by aammiitt
2086
Wood Textured Tiles
Last answer on 1/16/2015 11:37:30 AM. by John Son. Forum started by awdhesh
2325
Please let me know difference between vetrified tiles and porsoline tiles.
Last answer on 7/2/2010 3:30:35 PM. by jyoti. Forum started by Sudhakar
4042
How to Apply Ceramic tiles on roof Terrace
Last answer on 12/3/2011 10:27:48 PM. by newtondisc. Forum started by Pooja Panchal
2622
2350
Need Suggestion
2510
Tile roofing
Last answer on 1/13/2014 2:42:23 PM. by S L Gupta (Civil Engg). Forum started by sourabh
2104
Removal of cement grout from bathroom flooring
Last answer on 4/19/2021 5:32:20 AM. by Purvi Panchal. Forum started by Mrs Francis
1934
Sadrahalli
Last answer on 2/23/2021 12:45:32 AM. by sam_m400. Forum started by sam_m400
2521
Bathroom Flooring
Last answer on 12/31/2020 2:15:20 AM. by view interior. Forum started by vijay
3235
Bathroom tile cleaning
Last answer on 12/15/2020 8:22:53 AM. by leelindsey. Forum started by vandana
1850
Bathroom-water proofing and tiles
Last answer on 12/8/2014 10:03:14 PM. by JAI PRAKASH. Forum started by bhr2014
1782
My house is under construction and i have to go for plumbing therefore i want to
Last answer on 9/17/2014 10:59:54 PM. by JAI PRAKASH. Forum started by Avinash Sharma
1915
acid wash
Last answer on 3/24/2014 1:45:01 AM. by Purvi Panchal. Forum started by Mrs Francis
2364
2169
Hi, I am planning to put Morward or Agriya marble in my house. Size of the
Last answer on 4/9/2011 7:22:58 AM. Forum started by Rajnish Gupta
1716
Appreciated if i could get some advice on using granite stone and the shade, sin
Last answer on 9/23/2010 11:58:18 PM. by Ar. Manoj Ralen. Forum started by cruz
Tile
Tiles
Tiles for Bathroom
Designing
Bricks Quality
Fountain fogger/mister to bring the fascinating and mysterious quality to the fountain
The outdoor spaces in the months of June, July and August are very sweaty and sticky even at the evening time. It is lit
