Home -> Forums -> Construction -> Wooden flooring -> How to level concrete sub floor before installing wooden block flooring?
Mon Oct 06, 2014Total posts : 2
Topic: How to level concrete sub floor before installing wooden block flooring?
how to fix wooden flooring material to pcc below it
The comment above talks about the article   "How to level concrete sub floor before installing wooden block flooring?"
Mon Oct 06, 2014Post  #1
Plz check the link:
http://en.wikipedia.org/wiki/Wood_flooring
Tue Oct 07, 2014Post  #2
http://www.gharexpert.com/articles/Wooden-flooring-1426/Installation-Precautions-Wooden-Flooring_0.aspx
http://www.gharexpert.com/articles/Wooden-flooring-2280/How-to-level-concrete-sub-floor-before-installing_0.aspx
http://www.gharexpert.com/home/new_categorylist.aspx?PL=2&CATID=1349
Wooden flooring-Construction Questions (25)
3432
2052
2324
how wooden flooring is done
Last answer on 7/3/2020 11:14:47 PM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE
1982
what are the different good wooden flooring options available...pl suggest
Last answer on 5/23/2011 10:12:30 PM. by S L Gupta (Civil Engg). Forum started by Reena
2740
Wooden Flooring
Last answer on 2/9/2021 5:39:37 AM. by Prakash Pandey. Forum started by atiq khan
2003
Required PVC Wooden Flooring
Last answer on 10/18/2013 3:52:51 PM. by S L Gupta (Civil Engg). Forum started by Krishna Equytech
2097
what is wooden flooring and how it is done
Last answer on 10/6/2014 12:54:01 PM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE
2786
what is this floor made up of?? can we put glass in the wooden floor?
Last answer on 12/31/2020 2:29:52 AM. by Deepti. Forum started by ranjit
2439
I want to replace my kitch rooms existing flooring by wooden floor.Any suggessio
Last answer on 11/8/2010 5:56:44 PM. by Snigdha. Forum started by Anirudh
1981
Dear Sir,I need your advice on the new house, which I have recently booked and i
Last answer on 8/8/2014 10:57:40 AM. by Abhishek Vohra. Forum started by Esha
3325
2568
3597
3549
Reviews on Wooden Flooring.
Last answer on 12/31/2020 2:02:23 AM. by H S Rathi. Forum started by Gomsi Arora
1868
how this flowers are done. Is the flooring is wooden or tiles?
Last answer on 3/17/2011 8:37:01 PM. Forum started by parvathy
1998
Concrete Hollow Block Masonry
2027
3271
Roof Concrete Strength
2254
Pillar construction
Last answer on 8/17/2013 11:06:12 AM. by S L Gupta (Civil Engg). Forum started by SCK
2035
Laminated Flooring
Last answer on 5/29/2021 5:25:37 AM. by susandixon. Forum started by judyparker
2740
Wooden Flooring
2324
2616
Oak Flooring
Last answer on 7/3/2020 10:17:08 PM. by minks. Forum started by V. Vijayakumar
1804
Need Advice on Solid Wood Floors
Last answer on 4/30/2014 8:29:12 PM. by Abhishek Garg (Builder & Engineer). Forum started by chintan arora
2363
dampness in corners at the junction of walls and floors
Last answer on 3/9/2011 12:14:27 PM. by Nenni. Forum started by AN CHORDIA
How to Install a Sink
Installation of kitchen sink requires just few tools,material and a beautiful sink according to your needs. Read the s..
Concrete Decor
What is Glass Window
A transparent opening in a wall is called window. Usually windows are covered by transparent or glazed material like g..
Hardwood
Hardwood Flooring and its Installation
Hardwood flooring is one of the expensive yet elegent flooring option. Its installation is not that typical but still ..
Concrete Mix Ratio
