how to make footing and column for g 2 building on water well
Mon Mar 18, 2013Total posts : 4
Arun
Arun
Topic: how to make footing and column for g 2 building on water well
Tue Mar 19, 2013Post  #1
Dear Murugan
             I cannot follow your question, What type of information do you need. Write in detail about your question.
Wed Mar 20, 2013Post  #2
Arun
Arun
Post subject: column design on well
what is the procedure to make the column and footing (i need structural design)
i am going to build g+2 building , one well was there that plot.the well was close last year only,two column coming that area,so please explain the footing and column designs.
Wed Mar 20, 2013Post  #3
Dear Murugan
       As stated by you that there is well in the past, so there is every possibilty of shrinkage in the well area. Due to this fact there is chances of failure of foundation and also floor damage. It is advisable if you take the help of local engineer of your town or city, who will make site inspection and do the right solution. However for column construction and other RCC work, go to gharexpert site construction section and you will find lot about construction work material if you spen time on the website. For referance see link below
http://www.gharexpert.com/articles/Cement-Concrete-1644/Column-Frame-Structure-Building_0.aspx
Mon Apr 01, 2013Post  #4
Arun
Arun
Dear Gupta,
thanks your information,could you please give me the sample structure.
10048
3941
2957
Need suggestions
2260
m15 cost vs m20 cost
2176
New column footage and pillar very next to the wall of existing building
Last answer on 10/30/2014 5:27:13 PM. by Rachael Suggs. Forum started by Robert
6549
3278
2719
2039
option other than rcc deck / balcony @ residence
Last answer on 9/4/2014 7:34:32 PM. by D.P.S. Forum started by parth
3795
2069
beam and column
4940
COLUMN AND STEEL DESIGN
4940
1586
i want to knw cost about making a piller height 4 feet and 8*8
Last answer on 6/9/2021 8:12:51 AM. by ]Greis. Forum started by RUPESH RATHORE
2101
1967
while building an extension building next to old one the ceilings were kept apar
Last answer on 8/20/2011 2:20:45 AM. Forum started by D.Ramachandran
2568
17
18
Designing
Designing a Foundation
Orientation
Orientation of Building
Ready
Ready Made Doors
Are you looking for appealing ready made doors for your home? Here is a variety of ready made doors to provide safety ..
Cupola Proportions
Tips for cupola proportions
