Home -> Forums -> Construction -> Pillar Work -> How to plan steel dimention for load bearing pillars
Mon Aug 03, 2015Total posts : 2
Joshy
Joshy
Topic: How to plan steel dimention for load bearing pillars
i am planning to construct a duplex house(ground+1) , if future planning to add one more floor (ground+2) , as per the structural plan 16/12mm steel using for pillar. is it enough for ground+2 building ??
GF- 1200square feet & FF- 750square feet built up area
Mon Aug 03, 2015Post  #1
Dear Joshy
          Consult your structural engineer for MS Steel bars. The bar size is designed as per load bear by the pillars/ columns.
Wed Aug 05, 2015Post  #2
16 mm is enough for G+2 floors. Also check with your planner as well for the details.
Pillar Work-Construction Questions (39)
3608
2616
COLUMN nd LOAD BEARING
7257
5166
10048
2255
Sreel pillars(post)
4389
Last answer on 11/15/2016 1:51:43 AM. Forum started by K Srinivasan
4128
1764
2211
2525
2256
4925
LOAD BEARING STRUCTURE
7927
3424
3941
2427
RCC ROOF Requirements
Last answer on 5/22/2013 8:47:10 AM. by Rajesh. Forum started by Rajesh
2694
32560
Cost of RCC Pillar
6437
position of pillars
1878
column
1780
First floor plan suggestions
2523
Pillar cost
4036
42125
12461
First floor construction
2501
2503
Length of cantilever beam
2537
RCC column (pillar)
9228
pillar size in distacce
9195
2823
2694
1993
2208
3160
Laping length requirement
Brick Pillar
Specification of Steel
