Home -> Forums -> Construction -> Layout and House Plans -> how to proceed with plan approval by the authorities
Sun Oct 28, 2012Total posts : 1
latha
latha
Topic: how to proceed with plan approval by the authorities
 i am planning to construct a 2BHK house on the 2nd floor on my existing G+1 residential house at bhyraveshwaranagar(canara bank colony) in bangalore..
i am looking for the best, trust-able building construction contractors to take this order as full package since from planning, approval from authority & commencement till Z(end) level.
please suggest me how do i start with?
honest suggestions/guidance required on choosing best contractors of your experience.
look forward for your reply for the further process...
Mon Oct 29, 2012Post  #1
Dear Latha
Important Points for Construction
• Before starting a new construction project, check whether your area comes in a Earth Quake prone zone. While doing construction work safety measures should be taken for earth quake protection.
• The whole area of the building should be constructed at one time to avoid settlement in any portion of the building.
• If the construction is done in small portions, there may be chances of the settlement in foundation.
• All components of the building should be tied up with R.C.C. Band at plinth level/DPC level, door lintel level and roof level.
Works while Starting Construction
While starting the construction work by contractor at site after approval of the drawings and designs, the following works should be taken in hand.
• The site should be cleared if roots of the trees exist; they should be removed up to 2 feet below the ground level.
• Layout of the building should be done with fixing centre lines and 'burjis' or brick pillars etc. and mark all the walls, columns on the ground with their proper length and width as per designs or drawings.
 Plinth level/DPC level should be fixed keeping in view the H.F.L (High Flood Level) and surrounding buildings and nearby roads.
 Excavation for foundation should be done according to the designs and exact width and depth of the wall should be dug. If extra depth is made due to any reasons or any soft places found, those should be filled in with coarse sand or concrete.
• In case of excavation made through J.C.B. machine, the last layer should be done manually to avoid softening up to the base of foundation.
• In case the water comes in trenches, it should be pumped out immediately.
For more detail see the website gharexpert.com start construction section where find lot of material about construction see the link below
http://www.gharexpert.com/articles/Start-Construction-1528/Guidelines-while-Starting-Construction_0.aspx
1476
How much is the to approve land in chennai?
Last answer on 9/11/2013 3:13:25 PM. by Ahmed. Forum started by Manzoor
2486
Last answer on 9/20/2010 8:49:58 PM. Forum started by A Prasad
5425
Last answer on 7/3/2020 9:15:14 PM. by S L Gupta (Civil Engg). Forum started by kcp
2267
help from gharexpert for construction of house
Last answer on 9/23/2009 3:43:51 PM. Forum started by v d nagar
6580
1661
Construction Started Before Building Plan Approval
Last answer on 5/18/2013 1:51:00 PM. by S L Gupta (Civil Engg). Forum started by Rajesh
2815
how much will a flat sell without approval if its like 17 years old with 850sqft
Last answer on 3/6/2018 4:03:32 AM. by anandrao. Forum started by anandrao
1758
Is Basement allowed in 60*40 site
Last answer on 4/2/2016 11:40:07 AM. by S L Gupta (Civil Engg). Forum started by Surya
1198
Hi,Do i need permission from the respective authority to construct a G 1 in old
Last answer on 3/8/2017 11:14:32 AM. by S L Gupta (Civil Engg). Forum started by Kamal
12572
duplex house plan
Last answer on 7/4/2020 2:04:56 AM. by bindu. Forum started by sasikumar
2914
construction suggestion needed
Last answer on 12/21/2011 9:40:34 AM. by ravi at Dalmia. Forum started by rajan
1803
Does the plans purchased are by licensed architect or not
Last answer on 1/31/2022 11:39:06 PM. by Unoara Design Hub. Forum started by Ced Bowen
1350
I wish to construct first floor covering hall bedroom kitchen bathroom latrine a
Last answer on 12/12/2015 12:54:45 AM. by JAI PRAKASH. Forum started by Jaykumar N Nair
5988
Marriage Hall Construction
Last answer on 7/21/2021 4:45:40 AM. by Alexander Graf. Forum started by baskar20
4137
Last answer on 6/15/2021 7:30:34 PM. Forum started by baskar20
13025
Last answer on 7/4/2020 1:57:10 AM. by harshit agrawal. Forum started by baskar20
4317
Last answer on 9/9/2021 12:31:10 AM. by S L Gupta (Civil Engg). Forum started by baskar20
4620
Last answer on 10/12/2021 1:06:34 AM. Forum started by baskar20
2691
2924
2188
2184
2791
4520
1890
2284
2265
2766
3464
2356
1967
2241
3595
2324
2090
2792
1548
2114
How to Plan Outdoor Lighting
Girl`s
Girl's nest
Girl’s room is a nest for daydreaming, studying, playing with dolls, sleeping and even doing a little makeup and spend..
