Home -> Forums -> Construction -> Waste Water Drainage -> how to remove dampness in walls and roofs adjascent to bathrooms,without dismant
Sat Sep 18, 2010Total posts : 1
husssain
husssain
Topic: how to remove dampness in walls and roofs adjascent to bathrooms,without dismant
how to remove dampness in walls and roofs adjascent to bathrooms,without dismantling the bathrooms
Sat Sep 18, 2010Post  #1
Narender
Narender
Post subject: Replaster
Dear Hussainm
you can replaster your bathroom walls by adding wooden ash in the plaster morter.
you can use morter as specified below.
Cement 1
Morum or crusher 4
Pure wooden ash 2
you can just mix all the material and replaster the bathroom walls
just try
wishes
Narender
<div style="margin-left: 40px;"><br></div>
Waste Water Drainage-Construction Questions (25)
2363
dampness in corners at the junction of walls and floors
Last answer on 3/9/2011 12:14:27 PM. by Nenni. Forum started by AN CHORDIA
3490
How to solve dampness in wall
Last answer on 11/17/2016 10:58:15 AM. by Girish. Forum started by Rajan
2568
Removing dampness from wall
Last answer on 7/3/2020 10:31:20 PM. by JAI PRAKASH. Forum started by piyush
8421
Roof Beam crack
9893
1745
2032
Last answer on 1/28/2011 10:11:15 AM. by Nikita. Forum started by gururaj s sannakki
1506
Last answer on 10/31/2017 12:00:07 AM. by S L Gupta (Civil Engg). Forum started by div
1067
25609
CURING TIME FOR RCC ROOF
2350
Need Suggestion
2126
Dampness problem: In my new home, the house adjacent to me has dampness in the w
Last answer on 6/22/2009 3:15:25 PM. by Gunjan Utraja. Forum started by George
5124
3838
Roof Beam
2238
Good and latest Bath Room Wall Mixer
Last answer on 6/10/2013 6:00:38 PM. by elinahenry. Forum started by raghuam
2331
2321
2924
2031
whats remedy fr wall dampnass
Last answer on 2/25/2022 7:03:51 AM. by helloaarti21. Forum started by rakesh chopra
2766
2388
Sewage and drainage lines
2001
please help....slow draining in the bathroom
Last answer on 7/4/2020 2:24:02 AM. by mvnisha. Forum started by mvnisha
2505
2350
Traps - Types and Uses
Last answer on 7/3/2011 1:35:26 AM. by S L Gupta (Civil Engg). Forum started by SHAMS
Bathroom Pictures
Protect
Tiles
Tiles for Bathroom
Bathroom Cabinets
