Home -> Forums -> Construction -> Basement -> How to remove ton of sand from the basement with the help of vacuum pressure
Mon Feb 11, 2013Total posts : 1
ommu.sait
ommu.sait
Topic: How to remove ton of sand from the basement with the help of vacuum pressure
kindly any one advise how to remove approximate 6 ton of sand stored in basement where i have a access to basement with the window size access of 2'x4' ... can i remove the sand with the help of vaccum pressure... if i can ..where can i get this vaccum paver which can remove complete sand with the help of vaccum pressure...kindly suggest as soon as possible
Mon Feb 11, 2013Post  #1
akmurty1
akmurty1
Post subject: How to remove ton of sand from the basement with...
manual removal is best as the quantity is very small
1679
tool that add a valveto a 3/4in copper pipeunder pressure
Last answer on 1/17/2014 12:12:34 PM. by S L Gupta (Civil Engg). Forum started by anthony rodriguez
1428
Last answer on 9/28/2018 11:39:45 PM. by S L Gupta (Civil Engg). Forum started by Anand jaiswal
2867
2712
2016
coarse aggregate
3016
M-Sand for Plastering
3722
1774
1466
2142
3386
Diverters for Bathroom
6463
2931
2109
river sand
11320
2337
Sand units
1713
Sand units
1530
Sand units
4227
Selection of cement ..
9074
makan map
2791
17229
2001
2167
design of column
2296
2262
Underground water tank
2679
2775
foundation
2046
Full Plan Needed
3207
labour cost
3173
APP membrane
2814
1979
ffff
1879
4227
3480
2023
Regarding construction
3165
Basement Water proffing
2024
Acid staining
Basement Design Ideas
Vastu Guidelines for Basement
Carpet
Carpet Cleaning Tips
Basement Ceiling
Basement Flooring
Basement Interior Design
Copyright 2007- 2025 GharExpert.com All rights reserved.
