Home -> Forums -> Construction -> Dampness -> How to solve dampness in wall
Fri Nov 13, 2009Total posts : 3
Rajan
Rajan
Topic: How to solve dampness in wall
Hi:
How to solve wall dampness?
Rajan
Fri Nov 13, 2009Post  #1
Priti Arora
Priti Arora
Post subject: How to protect home from dampness
Please check out these links to know about how to protect home from dampness.
http://www.gharexpert.com/articles/Dampness-2016/Damp-Proofing_0.aspx
http://www.gharexpert.com/articles/Dampness-1386/Protect-your-home-from-Dampness_0.aspx
Priti
Mon Nov 16, 2009Post  #2
narendra barde
narendra barde
Post subject: My 20 yrs eperience as a civil contractor
There are many chemicals in market. You can use those as per the literature available. But, main problem is to find the source of dampness. If you do not judge the source of dampness you can not have a permanent solution. The reasons for dampness are many,
1. During monsoon,
2. Through out the year.
If the dampness is seen only during the monsoon problem is little simple. It must be from out side of the home. reasons here again are ample,
1. outside wall cracks,
2. from terrace,
3. from joints of chajjas and extentions,
4. from inlet pipes and cables which are not sealed properly, or any other which can be found on actual site visit by an expert.
If dampness is perineal i.e. through out the year,
Problem is little complicated. Reasons can be,
1. upper floor leakages in Wet areas i.e. Toilet, wash basin and kitchen areas.
2. It can be due to saline (salty) sand used during construction for internal plaster,
3. If the home is on ground floor,   the underground watr may comeup due to capilary action,
4. the water from wet areas of the same home can also be one of the cause, if you see dampness upt few feet from flooring.
This way there can be ample reasons for the dampness. One has to find the source and give exact treatment needed for it according to the source and cause.
The best way is to call experienced water proofing expert and try the solution suggested. and do work under his guidance.
Thanks.
Mon Nov 16, 2009Post  #3
Girish
Girish
after a Well explanatory advise from Narendraji
i will like to add on the brands which you can consider
Grace
Henkel Polybit
BASF
Fosroc
among the few which can be known and accepted in international market
As already been updated and advised by Narendraji, Identify the reason for Dampness and then a suitable method to counter can be provided.
Dampness-Construction Questions (35)
2379
dampness in bathroom,loft and staircase
Last answer on 8/19/2013 11:25:13 AM. by S L Gupta (Civil Engg). Forum started by Arun
3293
2363
dampness in corners at the junction of walls and floors
Last answer on 3/9/2011 12:14:27 PM. by Nenni. Forum started by AN CHORDIA
4138
2032
Last answer on 1/28/2011 10:11:15 AM. by Nikita. Forum started by gururaj s sannakki
2126
Dampness problem: In my new home, the house adjacent to me has dampness in the w
Last answer on 6/22/2009 3:15:25 PM. by Gunjan Utraja. Forum started by George
3227
Can VASTU DOSH NASHAK solve Vastu fautls ?VDatta
Last answer on 7/14/2021 6:01:41 PM. by sabina vanjani. Forum started by Col Vipin Datta
1585
Saralavastu plan I changed please solve that
Last answer on 3/5/2016 10:37:25 PM. by JAI PRAKASH. Forum started by arun s
50
Solve your love Dispute by taking Husband wife Problem 91-7681982445
Last answer on 7/5/2024 3:22:27 AM. Forum started by Miyan Akram JI
52
Last answer on 7/5/2024 3:22:29 AM. Forum started by Miyan Akram JI
55
Last answer on 7/5/2024 3:22:31 AM. Forum started by Miyan Akram JI
59
Last answer on 7/5/2024 3:22:32 AM. Forum started by Miyan Akram JI
58
Last answer on 7/5/2024 3:22:33 AM. Forum started by Miyan Akram JI
60
Last answer on 7/5/2024 3:22:34 AM. Forum started by Miyan Akram JI
57
Last answer on 7/5/2024 3:22:35 AM. Forum started by Miyan Akram JI
61
Last answer on 7/5/2024 3:22:36 AM. Forum started by Miyan Akram JI
59
61
Last answer on 7/5/2024 3:22:39 AM. Forum started by Miyan Akram JI
60
Last answer on 7/5/2024 3:22:40 AM. Forum started by Miyan Akram JI
2675
Damp Proofing
Last answer on 12/31/2020 1:53:13 AM. by Mike Perkin. Forum started by VIPIN
1862
Last answer on 12/24/2015 4:06:01 AM. by JAI PRAKASH. Forum started by sushantsah
1492
Canada Goose Chilliwack Bomber much likewise
Last answer on 11/14/2015 12:37:51 AM. by JAI PRAKASH. Forum started by farofaschafer
2073
2107
2132
Walls are damp in rain
2084
1885
Damp
Last answer on 4/4/2015 7:00:17 PM. by JAI PRAKASH. Forum started by Jag
1922
Leaking Ceiling
Last answer on 8/25/2014 8:26:28 PM. by JAI PRAKASH. Forum started by sandipvora
2762
1927
bathroom dampness
Last answer on 12/23/2013 12:21:54 PM. by S L Gupta (Civil Engg). Forum started by sunder
2570
Basement Leaks
Last answer on 10/24/2013 11:40:09 AM. by S L Gupta (Civil Engg). Forum started by Purvi Panchal
2531
Reasons of dampness
2366
water treatment for walls
Last answer on 4/27/2011 7:37:34 PM. by S L Gupta (Civil Engg). Forum started by gajender pathak
1749
2086
Last answer on 4/12/2010 8:36:47 PM. by haritha. Forum started by sujani
Protect
Reasons of dampness
Canvas
Canvas Wall Art
Which type of DPC recommended for the protection of dampness?
For residential buildings DPC consists of a layer of - 40 mm thick cement concrete 1:2:4 (1 cement: 2 Coarse sand: 4 g..
Wall
Wall Decor
Paint
