Home -> Forums -> Construction -> Plumbing -> toilet construction
toilet construction
Wed May 26, 2010Total posts : 2
j_maheshwari
j_maheshwari
Topic: toilet construction
I want to move toilet to another location in 2nd floor apartment. Is it possible and how do I take care of pipes which go thruough under the floor etc ?
Thu May 27, 2010Post  #1
Dear maheshwari
The sewage pipes which are to be laid under floor should be covered with cement concrete to avoid leakage. For more details you should see the articles on the website gharexpert.com link given below.
http://www.gharexpert.com/articles/Waste-Water-Drainage-1793/Guidelines-Plumbing-Sewerage-Pipe-Works_0.aspx
http://www.gharexpert.com/articles/Soil-Waste-Drainage-Sewage--1791/Various-Waste-Water-Pipes-Sewer-Construction-_0.aspx.
Wed Sep 07, 2011Post  #2
George Turner
George Turner
Too much hassle for my taste :P I would even consider moving if it is that big of an issue for your. But I guess it could be done, if you can get all the pipes up there.
Plumbing -Construction Questions (39)
1647
i have plan for 16'0"x55'0" plot NS 16'0" EW 55'0" one car parking two
Last answer on 12/5/2016 11:41:16 AM. by Beenu Phogat. Forum started by saravana prabu
1816
Is it advisable to have bath cum toilet in agneyam or near kitchen
Last answer on 5/27/2019 1:12:18 AM. by S L Gupta (Civil Engg). Forum started by shreenivas
1577
toilet in south west area of house, is it bad,what are remedies to correct it
Last answer on 12/23/2016 11:16:11 AM. by S L Gupta (Civil Engg). Forum started by sonia agarwal
1654
is there any problem having a toilet under the staircase inside the house?
Last answer on 4/5/2017 1:01:34 PM. by S L Gupta (Civil Engg). Forum started by aditya mishra
2636
25*18south facing house with bedroom,toilet kitchen and hall with steps
Last answer on 11/13/2017 1:46:28 AM. by S L Gupta (Civil Engg). Forum started by Harish
1164
my toilet is in east side.is any problem for that?
Last answer on 9/26/2018 12:04:39 AM. by S L Gupta (Civil Engg). Forum started by Arghadeep Som
1945
behind my poojaroom toilet is there is it inauspicious
Last answer on 8/6/2010 9:59:12 PM. by Rashmi. Forum started by shubha
3608
What can be done to remedy toilet and bath in north east
Last answer on 8/12/2010 4:21:43 PM. by sabina vanjani. Forum started by Sathya
2006
vastu for toilets
Last answer on 9/16/2010 2:33:14 PM. by sabina vanjani. Forum started by kiran kumar choure
3652
vaastu for east facing plot where should the toilet constructed
Last answer on 3/5/2021 3:03:04 PM. by nilu. Forum started by vankamardi
2007
hi what should we do my toilet seat in east side
Last answer on 12/29/2011 3:07:26 PM. by Amit Hasija. Forum started by prem
3680
sunken slab
Last answer on 7/3/2020 11:00:06 PM. by S L Gupta (Civil Engg). Forum started by chethan
3669
CAN WE CONSTRUCT COMBINED BATHROOM AND TOILET IN NORTHWEST
Last answer on 5/31/2014 11:05:07 PM. by JAI PRAKASH. Forum started by VIKAS
2317
Can we share a wall beetween kitchen and combined bath/toilet
Last answer on 6/2/2014 11:42:37 AM. by seema tyagi. Forum started by RAJESH
1837
where is toilet when our home facing is north
Last answer on 12/9/2014 10:19:24 AM. by seema tyagi. Forum started by rajeev sharma
2689
Last answer on 1/10/2022 11:40:17 PM. by seema tyagi. Forum started by vaishali
1988
One guest room,two attached bedroom,kitchen,toilet,puja room
Last answer on 10/21/2015 11:53:56 AM. by S L Gupta (Civil Engg). Forum started by anup Kumar
1884
New Construction of 25x56.5 area house
Last answer on 4/12/2015 6:01:24 PM. by JAI PRAKASH. Forum started by Pankaj
1666
Project cost for a hostel
Last answer on 8/20/2015 2:22:16 AM. by JAI PRAKASH. Forum started by Shiv Pyari Singh
6285
Water Tank Quality
3123
Hot Water Tank
2925
Sand in Water
3387
Diverters for Bathroom
2572
2169
40577
2095
GI pipe Vs CPVC pipeline
2945
1762
2087
Toilets
1998
Wall mounted cummod vs normal
5071
2790
2394
1866
3094
Swimming pool
2554
water softner
2691
commode type and flush type
4211
to shut off water to house
Utilization
