Home -> Forums -> Construction -> Start Construction -> type of brick
type of brick
Wed Dec 04, 2013Total posts : 1
neelam rathi
neelam rathi
Topic: type of brick
which bricks to use for construction?fly ash or the normal red bricks?and what is the difference in cost per sq.ft.
Thu Dec 05, 2013Post  #1
Dear Neelam Rathi
            Use clay bricks/ normal bricks in construction, to know about more see the link below
http://www.gharexpert.com/articles/Bricks-887/Specification-Brick_0.aspx
Also see about fly ash bricks
Dear Abhishek
           Fly ash bricks are generally used for making curtain and partition walls of the houses/ buildings. Fly ash bricks are used in domestic building in the category of low or middle-income groups mostly have single  storied dwelling units. Use of fly ash bricks in this type of construction is meant mainly to achieve economy and make profits.
PWD-DELHI Issues Circular for Use of Fly ash Brick
“The PWD-DELHI department Suggested Experimental Use of Fly ash bricks in Site office, Temporary Accommodation/ Boundary walls”
3118
concrete brick or clay brick
2038
Various Types of Bricks
Last answer on 1/17/2011 12:25:46 PM. by chandru. Forum started by manoharan k
2047
question
Last answer on 4/15/2013 12:34:12 PM. by S L Gupta (Civil Engg). Forum started by arpitbedi
2697
Last answer on 2/20/2014 11:14:47 AM. by S L Gupta (Civil Engg). Forum started by HM12345
2992
2017
3651
18382
2962
3928
2873
FLYASH OR CLAY BRICK
4179
GLASS BLOCKS / BRICKS
2350
4056
2024
3271
Door Frames
Last answer on 10/22/2010 12:50:15 PM. by Mohammed Moin. Forum started by Mohammed Moin
3560
Cost of construction
Last answer on 3/19/2013 11:44:19 AM. by S L Gupta (Civil Engg). Forum started by saurabh ramya
2417
2364
Ugly brick wallI would like to cover my brick fireplace wall. It is a blonde br
Last answer on 7/9/2012 3:21:23 PM. by Ar. Manoj Ralen. Forum started by Lynda
3311
2312
Bricks Quality
Specification of Brick
Brick Arches
Brick Tiles
Flat Brick Tiles should confirm specifications as per IS-1077-1992 and must be homogeneous in texture.
Brick Pillar
Buying tips for Bricks
